Dash cam recommendations?
fwashjr
frank
baltimore
maverick xlt
Just wondering what dash cam you guys/gals have chosen for a dash cam what make and model and what you like or don’t like about it - Thanks
Dave O
New Smyrna Beach Florida
I am waiting for my Wolfbox G900 TriPro Cabin Dash Cam to arrive
rth121
Monterey
2022 Ford Maverick XL
Depends on how much you want to spend and what features you want...
3 channels:
Viofo A229 Plus
Vantrue N4 Pro
2 channels:
Viofo A329
1 channel:
Vantrue E1
Viofo A119 Mini 2
Mirror type:
Wolfbox G900 Tripro
Nexigo D90 Gen 3
ThirdCoastBoomer
Reid
SE Michigan
2025 Maverick Lariat
Check out the Rove R2-4k PRO. I purchased one along with its hardware kit and have been very happy with it. It's forward looking only, though.
Which brings another consideration, are dual systems worth the money and installation hassles?
Ryom
PA
2025 Lariat 4K BAP Eruption Green
Yes. Accident can happen from any angle. If you don't like the idea of a long wire from the front, just install a second dashcam in the back and plug into a rear 12v port, USB port, or tap an accessory in the back.
Toddman45
St. Louis, MO
I really like my Cobra SC 250 R front & rear cams. Video quality is great day or night.
They also sell a hardwire kit that plugs into the OBD2 port and is passthrough as well. So the OBD port is still usable. There is also a usable in cab camera aswell sold separately if so desired, for a 3-channel setup.
Ford Maverick Dash cam recommendations? PXL_20240906_053221704
Ford Maverick Dash cam recommendations? PXL_20240906_053424789
Ford Maverick Dash cam recommendations? 20240913_155423
sunglint
Wayne
Houston
2022 Hybrid
I have a no-name mirror type I bought on Amazon several years ago, I bought it because it was one of the only ones at the time that used the entire mirror area as the screen. This is the third vehicle it's been in. Just today I bought one on Ebay that has front, rear, and two side cameras, and gps, which my current one lacks. I'm interested in the side cameras, mostly to augment the mirrors. I also like the mirror kind because they are usually larger than stock mirrors.
When I have to drive a fleet vehicle at work I have a small one that suction-cups to the glass, and has a rear-facing camera on the bottom.
I carry an sd card reader in the glovebox that works with my android phone with a small card in it, so I can copy a video and give it to someone if needed.
it's quite easy to route the wires down in the Mav, no need for dangling.
WJOHNM
New York,LI
I have the Viofo 119 about 100 bucks front only basic unit took 15 min to wire, plugged into dash not fuse box, powers off when you turn off truck, wire is completely hidden stuffed in headliner and down right A pillar simple install covers front of vehicle with very clear images, I figure if your hit in the rear their at fault 95% of the time unless your backing up no need for coverage. Check that guy on UTUBE that reviews any and everything he reviewed a lot of units and does a great job he buys they all no handouts from company's he thought the Viofo was the best. Its small, has a screen and can see images on phone can't go wrong for 100 bucks.
semicolin
Ontario, Canada
2025 Maverick XL
I have been using a Viofo A119 for years and it blows everything else out of the water. I have the hardwire kit installed so that it turns off the camera when the battery voltage drops, and it enables parking mode to just capture moving objects.
Great camera with a really good picture.
Whyjohnm is referring to this video from Project Farm: The Truth About Dash Cams!
Jersixmlp
Alex
2021 Ford F-150 Lariat
I was debating between a few options too, then found this list: https://www.insta360.com/blog/tips/best-dash-camera-for-cars.html. Super helpful breakdowns without the tech jargon. Ended up picking one from there that had a solid parking mode and decent night quality, which was my main concern. Install wasn’t bad, and it tucks nicely behind the rearview so it’s not staring me in the face while driving.
SafetyGuy
Andy
Manitoba
I also have a 2 camera system, front and back facing, and love them.
Many good ideas to work with here and the previous threads on dash cams...and I will add here as I have previously, watch a few installation videos to make sure you install the wires so they won't interfere with your side airbag inflation when routing!
As a recent thread has shown, Mavericks DO get hit from the side as well as the dreaded "small truck is closer then it appears" rear-ender!
The side airbags worked as designed/hoped for in the incident and reduced the driver's side impact injuries to a minimum...considering everything.
You dont need a lot of things, till suddenly you do.
Andy
converseguy
2023 Maverick Lariat Hybrid, 2024 Toyota Prius Limited
I have no experience with this unit but Tim at Long McArthur did a review of a dash cam just today...
Pappamoto
Ken
2025 Ford Maverick Hybrid Lariat Shadow Black w/BAP
I just finished installing a Wolfbox G900 Pro. Was very easy to install. Took around 30-40 minutes total. My only complaint so far is that I mainly bought it because I wasn't happy with the rear-view mirror that comes in the Maverick. This camera definitely opens up the rear view, but the video is very choppy. I wish they would put more effort in the rear camera since this system replaces the rear-view mirror. The front camera doesn't seem to be choppy at all.
Gonzo_042
Gonzo
I went with the same concept for my 2022 Maverick. It was hard to see anything if I had passengers in the rear seat. I had the Auto-Vox mirror in my Mustang and decided to add the Auto-Vox V5 Pro to the Maverick. Mine has a 1080p rear camera. At night, depending on the lighting, it can get a bit choppy. Overall, very happy I have it. The installation was easy once I got the camera cable in the cab section behind the rear seat.
