Cutting corners
MLowe05
GA
I just went down and saw some similar light surface rust in the strut/spindle area on both our Honda Odyssey and Mazda CX-5. I've seen this on before on a Nissan Frontier's driveshaft and on brake rotors on many vehicles.
Light surface rust and hastily ground down suspension components are two different things. And brake rotors is a terrible example - those rust on basically every vehicle.
upnash
Ohio
Saturn Vue, Dodge Grand Caravan
Please provide examples of other vehicles with this sort of workmanship. I've owned cars from every Japanese, Korean, and German automaker and not a single one has had anything like that. Excusing it for cost is not an acceptable answer.
Perhaps this is a Ford thing. It is not a thing at any other manufacturer - at any cost - that I'm aware of.
in 2010 I bought a new Toyota Tacoma. It had several what I considered serious recalls. Toyota recalled the truck to inspect and repair the frame for rust through in the northern states. If it was in danger of frame rust through they woul replace the whole frame. If they considered it ok they would clean and undercoat the frame ( I got undercoating).
Then there was the rear leaf springs which could break unexpectedly and puncture the gas tank ( I got new springs)
And the airbag recall which included many brands.
Having said all that it was a great and reliable truck. I sold it because it rode Like a truck and as we get older my wife wouldn’t ride in it anymore.
Finnster
N. E. Wisconsin
I'm sorry for having higher expectations after 10 months of waiting. Maybe my concerns are unwarranted. Maybe after 30 years of driving I shouldn't have expected anything less from Ford. It's my first one and I'm feeling like it may be the last. Hopefully I'm wrong.
Absolutely no need to apologize! I was shocked at first seeing your pictures and I intend to inspect my spindles and the rest of the suspension, should I ever obtain a 2023. Not that I am concerned, just curious.
Actually, of all the cars and trucks I've owned over the last 20 years, none of them came from the factory with a factory coated spindle. therefore, there was no shock upon seeing an uncoated spindle that had been machined to make it true! Spindles are a wear and tear item and aren't necessarily made to last forever. In addition these Maverick spindles look quite robust and they will be one of the last components expiring from rust!
The spindles from my son's 1996 Saturn would have shocked you! They appeared fragile and they were! Not to mention the wheel bearing failures every few years.
W8ting4u
Paul
2011 Buick
Very common to machine that surface perpendicular to the tie rod bore. I would be more concerned if they just left the cast surface unmachined. FYI the casting will probably rust through 10 years after the trucks been recycled.
TMAC
Riverside County
22 Maverick & 94 Silverado
I learned to work on front ends, suspensions, brakes etc. in my teens. I still remember vividly being taught how to release tapered ends from Ball Joints and Tie Rod ends. I was taught to use a FIVE POUND MAUL AND SWING AT THAT CASTING AS HARD AS YOU COULD, AS MANY times as it took to break those parts free. Those parts are engineered to withstand high speed impacts, maybe hitting a curb sideways. I have never seen one broken. Don't pet the sweaty stuff.
Ford Maverick Cutting corners Surfer Baby copy
2022EOW
Marty
Missouri
2014 Focus
What type of failure issues do you see that this will cause? Heck you better not park by the beach for a few days if this concerns you, your brake rotors will have surface rust them. Yeah it’s an eyesore that can be fixed with a few squirts of rust inhibitors.
For me it’s a non issue.. I have a 2021 Ranger that shows surface rust on some of the undercarriage components.
Exactly. I just got rid of my 18 year old Sport-Trac which was never garaged since I bought it new. Undercarriage was a rusty mess, but nothing failed, no body rust, and it was out of sight, so who cares.
Dudley
Doug
Indiana
2003 Grand Cherokee
Good thing it's not a $14,995 truck! It'll prolly come in a box and have to be built by the customers themselves!
"For the XL AWD Hybrid please go to Isles 14, 15, 16, 23, 24, and 25 and get one item from each shelf in color desired. For FWD only do not go to Isle 25. For the Ecoboost option go to Isle 27 instead of 24. For XLT substitute Isle 13 for Isle 14 and for Lariat substitute Isle 12 for 14. For all options, please check with customer service for availablity (good luck!). Assembly required. Please carefully follow the stick figure people with lots of arrows and symbols in pictures provided in the 350 page book. Words to say when frustrated provided in several languages. Tools not provided."
WNYEscapee
TJ
BFLO
2023 Maverick, 2019 Cherokee
This is normal, I've been in the industry for nearly 30 years, and this is completely a normal process of production. It might be more noticeable because the casting is painted so the machined portion stands out, but it's just a machined area to allow the nut to seat on a trued surface.
Red Ryder
United States (TN)
22 Maverick XLT Iconic Silver
Hastily ground down, eh? You can determine how long it took to produce those parts based on these photos?
Stevo
Stevo
Chicago
Lots
It isn't
It isn't about having higher expectations, it is about having appropriate expectations for what you are paying for. This is the world we live in these days, no matter the manufacturer...foreign or domestic. You get the acceptable grade for what you are paying for. . There is "nothing" truly wrong with a final grinding on a 20k base car. On a Porsche/Lincoln...definitely. just be happy that you have the maverick, because just wait to see what the prices are next year. Inflation is the silent killer. You have a new mini truck that is going to treat you great for the next 25 years and will get great fuel economy that you paid in the low 20s for.
MLowe05
GA
It's a mass produced truck, so you can safely assume the parts don't take long to produce. But yes, in terms of how it was shaved, you can easily tell that is pretty much a hack job.
You guys have much lower standards than I do, apparently, but looks like this is probably an isolated case. And even if it does not cause issue, it is still symbolic of the type of build quality you're getting. This whole "it's 20K" argument is flawed as the Maverick is not the only $20k vehicle on the market.
MLowe05
GA
If this were acceptable, surely I would have come across it by now having owned MANY vehicles over the years that had similar pricing - Kia Souls, Elantra, Forte, Kicks, Corolla, Civic, etc - all in the low $20k or below. Never saw anything like this on any of them.
The other thing that sticks out to me is the "Porsche/Lincoln" thing. Those two do not below in the same sentence, much less divided by a / - they are worlds apart.
90.eunos.cosmo
Alexandre
2014 fiesta ST, 22 ford maverick
So after almost 10 months I figured I'd have a truck that was 100%. I had to imagine that Ford did whatever it takes to get trucks out for 2022 and by "whatever it takes" I was hoping it wasn't literally. I wanted to change my wheels out. And low and behold, corners were cut, well not corners but my spindles. Tops trimmed to mount the shocks and as you can see the really hacked the area to mount the tie-rod. Not real happy with my first ever Ford. Has anyone else had this issue? XL Hybrid 230 miles. Who can I contact at Ford? Dealer is aware of my issue.
I don't see the issue, most cars are made like that now a days, i've been a automotive tech for 10 years and its very common to see that... here's a brand new one for another vehicle for reference
Ford Maverick Cutting corners 41dJFxgFjyL._AC_SY780_
rmay635703
Ryan
WisConSin
Subaru 360, Comutacar, Honda Insight, Dodge Ram
Here is how GM does it, it’s a replaceable part so why use anything better than old tin cans?
Ford Maverick Cutting corners image
