Consensus on preferred engine oil?
Darryl
Darryl
Tallahassee Florida
2025 Maverick XLT HYBRID
Since I work at Ford, I'll use the recommended 0w-20 Motorcraft full synthetic oil. If I didn't, I'd use ANY brand of full synthetic 0w-20 except Quaker State. Quaker State is probably fine too. But my Dad didn't like Quaker State based on the1960s and 1970s formula that would sludge up. So I followed suit. 😅
inline_five
2023 Hybrid XLT
Valvoline Restore & Protect 0W-20 is hands down the best value and performing motor oil out there right now IMO.
It basically stopped the oil burning from stuck rings in my wife's 140k mile Prius which had run Mobile 1 from day one. And BITOG is full of fantastic wear numbers.
For hybrids it's the best out there IMO.
That being said, pretty much anything you throw into the 2.5l Duratec will be great. It's a fantastic motor.
Leon Hogan
Leon
north central Texas
2026 xlt hybrid
matmondro
Mathieu
Vassar, MI
Leon Hogan
Leon
north central Texas
2026 xlt hybrid
You have to go out of your way to find a bad motor oil these days. Valvoline is probably the best brand though, particularly the restore and protect product for high mileage engines, but not many Maverick owners are in that range. Pennzoil Platinum is also consider slightly better than the others.
I use SuperTech with a Premium Guard XL filter. Used oil reports on this forum convinced me to go from my usual 5,000 interval to 7,500 at least. The filter matters just as much as the oil for extended drain intervals.
motocraft FL-400S or equivalent is a higher capacity filter with same micron filtration and bypass pressure specs.
Tbone289
For the curious, this is my 2012 2.0L Duratec Ti-VCT run on mostly Quaker State Full Synthetic 5w-20 (with some Motorcraft and Safety Kleen recycled blend at times) at 150,000 miles with 8,000-mile oil change intervals.
I think I'm fine with Quaker State. ;) It's not the sludge factory it was 50 years ago.
Ford Maverick Consensus on preferred engine oil? 1780579215308-2h
commadorebob
Do oil changes. That in and of itself will do more for your engine than the flavor.
Cycopath
Tucker
FL
2026 Maverick hybrid AWD
I’ve read many articles and suggestions on Maverick preferred oil. I have a 2024 Hybrid and would like to know what is the suggested oil from this group. Thanking y’all in advance.
I've long been a believer in Mobil 1, and will be using it once my first maintenance is due.
kevinmccune
kevin
BATH CO ,VA
2022 XL maverick
green top(nd) Quaker state the old timers liked it for some reason( maybe henry ford liked it in the old flatheads) guaranteed sludge in no time,new Quaker state should be fine,the only use for a ND oil(probably because of foaming) would be some old compressors.
Tbone91
Fulton, NY
2024 Ford Maverick XLT FX4, 1991 Chevrolet Camaro RS
My 2 cents here, I use Mobil 1 full synthetic in everything before my Maverick. Currently I go to the dealer and ask for full synthetic, not part synthetic. I'm only on my second oil change now. My 1991 Camaro I run full Synthetic Mobil 1 with a K&N oil filter...I'm sure I'll get ridiculed for this but I'm ready 🤣 I will say pretty stock, original 305 in it with just under 140k miles. I do have a high volume oil pump with a very mild cam, hence the K&N filter. I think it helps keep the flow going better, does it? 🤷‍♂️ it still runs like a banshee when I want it to...although my Maverick EB would probably smoke it, she's still fun to drive. My experience in a high end German dealership for over 20 years says run whatever you want. It's your vehicle. My only suggestion is never go to Valvoline quick oil change place or a Take 5. Most are learning to do oil changes on your pride and joy. I've seen too many horror stories first hand. I do know my dealer uses Valvoline oil or Motorcraft. The reminder sticker on the windshield says Valvoline on it. Good luck! 🙏
doug maverick
Doug
2023 Ford Maverick Hybrid
Watch the old Bugs Bunny cartoon - RABBIT SEASON! - DUCK SEASON! At least there is only two answers on that subject.... :)
WJOHNM
New York,LI
Here we go again!! I like it with butter.
