How often to change engine oil on a hybrid Maverick?
RedRider
Kitchener, Ontario, Canada
2013 Fusion, 2023 Maverick on order
How often do you change your oil on a hybrid? Ford recommends 0-20w Synthetic Oil at 7-10,000 miles for Hybrids. Now if 1/3 of your mileage is electric you should be able to extend oil changes. Using synthetic oil I always went 10-20000 on my previous vehicles before changing it with no problems. Chemist have told me that oil doesn't wear out it only breaks down under heat and pressure like race cars.
I suspect that it will need changing more often than you are used to, since it spends much longer lubricating a cold engine than in a more conventional ICE. Its going to be like a more normal engine running only 1-mile trips for its entire life. In a cold engine, the oil does not flow as well as in a hot one, and this is only partially compensated for by running the specified 0-weight oil. You're also likely to have a much higher fuel load in the oil that does not get burned off. After the break-in period, maybe get the oil tested to confirm or refute those thoughts.
22XLThybrid
Paul
York, Pa.
2022 Maverick XLT hybrid (order July 21)
The oil change graph on the app is useful if your too lazy to scroll in the dash. It gives you estimated miles and month it's expected to be changed. If it sits in the garage for a week, it moves down a percentage points drive a lot it moves down quicker. I feel pretty confident in the factory oil change system. This isn't an EcoBoost with high cylinder pressures, associated wear, and a turbo to roast the oil. I'd probably change at 5K for those.
Reconditioner
Rusty
Farmington, maine
If you have to ask, it’s time!
luparguru
Robert
Northlake, TX
2023 Ford Maverick Hybrid Lariat
Oil changes remain a relevant topic for me. I'd say at least once a year or at about 15% oil life. For me, I'll easily make 10k miles or 1 year. That's if I were in control of the interval. I'm currently dealer bound and I have a maintenance contract that says 5 years 8 visits, 7500 service interval. I also have to take it in at least every 7 months to maintain lifetime loaners and inspections. The Maverick is my only car as of yesterday. I'm trying something new here with dealerships and lots of road trips.
Ditto
ckodsi
Camille
Maryland
Maverick Lariat Hybrid
Every 7500 miles free of charge as long as you own the vehicle at my dealer, Apple Ford of Columbia Maryland
GreenLady
Jeannette
NE FL, NC, SC
Mine came on at 21,000 miles. I have full synthetic and when they changed they said it was still pretty clean.
2lbgill
2lbgill
Don
Upper Peninsula MI.
2023 XLTHybrid
WE live in the boonies up here in the U.P. of MI and the nearest town is 8 miles which is plenty of time to get warm and I never heard of fuel load before as engines are pretty efficiant at burning fuel with fuel injection these days. I did a lot of dyno work on engines over the years in a engineering background and have never heard of the term.
Old Man
Nebraska
2023 Lariat
The oil change minder usually have mileage and time built into them. My last three vehicles the change oil notice came on at 11 months (I don't drive 10,000 miles in a year). If that notice comes on you should to a change whether it is based on miles or time. The system probably keeps track of when the notices are displayed so if you have an engine problem they can check to see if it displayed and ask for your oil change records.
If you tell them you used Mobil 1 that said 20,000 miles on the label they will tell you to have Mobil fix your engine.
On the other extreme there are some that believe in the Jiffy Lube 3,000 mile change schedule because they think they are driving cars from 50 years ago with oil from back then. A few years ago California was going to pass a law stopping that practice because of the millions of barrels of oil that wastes. Instead they passed the law requiring all new cars be EV by 2035.
72Maverick
Memphis
Ford Expedition, Maverick Hybrid
To answer your OP, if you ask 10 people you will get 10 different answers. I tend to over maintain my vehicles, just my way of erring on the side of caution. I changed the oil/filter on my hybrid at 3000 which was probably a little soon but it did have a fair amount of metal you could see in the sunshine in the drain pan. I expected to see a small amount as the engine was breaking in. With a cost of around $26 using Kirkland 0w20 synthetic and a Motorcraft filter, I'm going to change it every 5000 miles from now on. It's an easy vehicle to change but you do have to take a few fasteners off to get the shield off before you can access the filter and drain plug. I expect the engine to be the last part that wears out on a modern vehicle if it's maintained and I haven't heard of an engine failing because the oil was changed too often. If I was taking it to the dealer paying $59.95 and waiting in the purgatory room with terrible coffee, I'd extend that to 6-7000 miles.
ckodsi
Camille
Maryland
agree with 72 Maverick
FriscoTXJoe
2022 Maverick Lariat
I used to be a 5K guy no matter what. Did the math on my 170K Hyundai Tucson. I did roughly 32 oil changes at about $60 a pop. (Used a national chain close to me.) That's $2K worth of oil changes over 5 years. (I drive an S-ton.) With the Mav, I am following the oil life monitoring and have had 3 so far when I was at 26K on mileage.
Oil is better now. Filters are better now. Vehicle monitoring is better now. I am comfortable following what the MFG says to do. Why do it more often if not necessary?
Hardening2753
Lol he actually got his oil tested that's why it's such a higher change interval for him. I said all the same things you said too and he proved me wrong
Hardening2753
Lol that's one way to get rid of oil changes
huunvubu
coppell tx
When either the "Oil Life Monitor" says to or one year whichever occurs first.
