Remote engine oil filter for 2.5l hybrid engine
azadv
Jerry
AZ
Hybrid XLT
I'm wondering if anyone has a parts list or kit for relocation the oil filter on the 2.5l engine to somewhere in the engine compartment to allow it to be changed without going under the vehicle and removing the plastic bottom aero cover. I can already drain the oil from the dip stick tube using my LiquiVac evacuator.
Thanks...
TheSEARCH
Dan
ford
I wouldnt drain/suck it like that with a vacuum up the dip stick . Junk settles to the bottom of oil pan hence draining will do a better job. But its up to you.
There is a metal cover with cut outs for drain plug and oil filter. Plus I did see on this forum were a guy modified his plastic cover with openings.
azadv
azadv
Jerry
AZ
Hybrid XLT
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
This would be the first time I've seen someone ask this question since the truck came out in 2021, all I can say is good luck.
CurtisB
2023 Maverick XLT Hybrid
I'm sure there is an aftermarket kit somewhere that will do this. I would google it. I did a kit on my 2015 Prius to convert it from the ridiculous plastic filter it had to a regular spin-on type.
