The harness with the "bad" end is 12v (it is black and not orange) and is from the 12v to the dcdc converter with drops in between for different things. The deep sleep occurs when 12v drops to a low voltage that cannot trip contacts for the hvb and ready the vehicle. There are many things that could cause phantom drains on 12v. I have voltage monitor in my XLT LUX dash PowerPoint and I turn key to accessory and read bus voltage (it is an open circuit reading so is affected by whatever is drawing current). I have never had lights not come on or deep sleep. I have seen overnight drops of 0.1-0.2v between readings 2 hours after parking and next morning. I have seen voltage as low as 11.6 but normally higher. If it's less than 12.1v I will place truck in ready state and charge battery. I think I drive mine often enough that I shouldn't have deep sleep or even light problems, but my concern is long term battery health which could be offset by monthly or quarterly use of my noco maintainer.Yes, I've seen that and understand the concern. It is becoming a concern for me as well, just something I never thought would be a problem.
I am wondering if this is a real world issue or just something that happens when something else is wrong. For example many (most?) of the complaints I have seen about the deep sleep issue seem to eventually lead to being caused by a failure of the HV battery harness and thus the 12v battery not getting charged.
So my question is: if there is no problem with the HV battery harness is there then no problem with the 12v battery system going into deep sleep in a reasonable time? For me 'reasonable' would be letting the truck sit untouched a minimum of 4 weeks. I think a vehicle that goes dead after sitting only a month is a complete travesty.
Yes we can add battery maintainers, but why should we have to?
