SuperDave71
Carthage IN
Ford F-350 CCSB 6.7
I don’t think so, just a fluid change in the manual, that might be for the 8speed eco only
Waterick
Laurens county SC
jcs
San Diego
2025 Maverick Hybrid XLT
Thank you for this write up! I'm saving it for when I have to do mine at around 30k miles.
blizbiggy
Robert
Ohio
23 Maverick
I appreciate this post. I'm sitting just shy of 25k and will probably do this service every 50k miles.
JohnCondren1933
Henderson, KY
Maverick XL
I think you are correct. I looked around more and it looks like the family of HF35-45 you have to open the transmission completely to replace the filter
If you're going to split open the HF45 hybrid drive to replace the filter, you might as well also replace the roller-bearings & oil-seals - once every 150-200,000 miles
SoonerBrink
Joseph
Nissan Murano
Has anyone changed the fluid without lifting the vehicle?
Hardening2753
Hardening2753
Ford Maverick Hybrid
You don't really need to lift the vehicle up any higher than what it is, you just need to be able to take the wheel off. In a pinch you could use the jack that came with the truck. But you can buy a jack stand and a jack pretty cheap at Walmart and they work good
rslilly76
rslilly76
Corpus Christi Texas
2025 Maverick XL Hybrid Fwd
10k miles I'll be doing this.
We just did my son's 22 ecoboost
skinnyboy
Andy
Ontario, Canada
If you can shimmy under to get the under body cover off and the drain bolt out, then it could be done. You can fill the trans. by turning the wheels to the left to get access to the plug.
Cheers.
SoonerBrink
Joseph
Nissan Murano
Cheers.
My guess is the cover is probably gone already from the dealer doing the oil changes. I wonder how much that affects mpg?
brianbgw
WA
2025 Maverick Hybrid AWD
Has anyone been able to find the part number for the drain and fill plugs? I'm having a heck of a time finding anything the the hybrid (HF45 or HF55) transmissions, seems the Ford and Lincoln parts pages always take me to the 8F35 ecoboost transmission. Anyone have a pic of both of them? O-ring seals or thread sealant or what are we talking about? I always just replace them when I do a service to ensure I never have to worry about leaks.
brianbgw
WA
For reference this is the drain plug I’m really struggling to find a part number for.
Ford Maverick Changing The Transmission Fluid on Your Hybrid Maverick (DIY Step By Step) IMG_6134
grcmptrnrd
2025 XL Hybrid
I did this recently on my 2023 Lariat Lux Hybrid. While Ford and other manufactures say some fluids are lifetime, that's just because they want to say that it is cheap to own a vehicle. Due to the driving style and conditions that the truck operates on I have to preform regular transmission drain and fills. You can do this with Walmart or Harbor Freight tools. If you have done an oil change you can drain and fill a transmission. While this is specific to the Hybrid, it likely is the same for the EcoBoost (and JK jeeps for what it's worth just different sockets and fluid).
You are responsible for your actions and assume all risk.
Tools
  • 3/8 ratchet
  • 3/8 extension - 5 inches
  • 14 mm socket - Transmission drain bolt
  • 10 mm hex socket - Transmission fill
  • 21 mm socket - lug nuts (or use the one that came with truck)
  • 4 mm hex socket - under engine splash guard
  • Flashlight
  • Funnel
  • Mop bucket or oil receptacle
  • Safety glasses
  • Mechanix gloves
  • Truck Jack
  • Jack Stand
  • Tire chock
Supplies
  • Paper towels
  • Nitrile gloves
  • degreaser
  • 6 quarts of Motorcraft Mercon ULV (toxic)
    • I always get extra if I spill
Step By Step
Lifting the truck
  1. Activate the parking brake
  2. Loosen but do not remove the lug nuts (21 mm socket)of the front driver tire
  3. Chock the rear tires
  4. Jack the truck up
  5. Put the jack stand and lift to appropriate height
  6. Remove the tire and side it next to the jack stand
    1. If the jack and stand both fail the tire will function as a stand as a last resort
  7. Remove the under engine splash shield
Draining the Transmission
(Note: the blue line is me bolt marking it after I filled it. It is not there from the factory)
  1. You will open the fill plug first (picture 1)
    1. This is to ensure that you can fill the transmission. If you cannot remove the fill plug abort and call a mechanic
  2. With the 10 mm hex socket remove the transmission fill plug
    1. Mine was pretty tight and I had to use a breaker bar
  3. Place the mop bucket or oil receptacle under the oil
  4. Remove the Transmission drain bolt using the 14 mm socket (picture 2)
  5. Let the transmission oil drain
    1. It is normal for some metal flakes but they should be small
Filling the Transmission
  1. Tighten the transmission drain plug. I did 1/4 extra after it got tight
  2. Measure the amount of transmission oil that wan removed. This is the same that you will add. I had 4.2 quarts come out and I put 4.5 back
  3. Using the funnel begging to fill the transmission through the fill hole
  4. Transmission fluid will start to leak as you get near the amount you removed
  5. When full, tighten the transmission fill bolt. I did 1/4 extra turn after it got tight.
  6. Congrats you did a transmission drain and fill!
Finishing
  1. Replace the tire
  2. Finger tighten the lug nuts
  3. Make sure there is nothing under the truck
  4. Jack the truck up some to remove the jack stand
  5. Slowly lower the truck
  6. Tighten the lug nuts
  7. Turn the truck on
  8. Cycle from parking>reverse>neutral>drive 4-5 times
  9. Road test the truck by driving it to a local car part store to recycle the transmission fluid
  10. Enjoy a cold beverage when you get home
For reference, the HF55 - 2025+ has moved the fill plug. It cannot be accessed from the wheelwell unless you remove the liner.
It can be accessed from below with the engine splash shield and screws securing the bottom of the wheel well liner removed & liner pushed towards the wheel. A couple of YT videos show this along with the attached image. A bungee cord helps hold the liner back while working.
2 stacked 2x6 boards under the front wheels was enough for me to shimmy underneath and with the slope of my garage had the truck very close to level.
Unless you remove the wheelwell liner you will need a pump or pressure filler to get the fluid in.(~$30 on eBay/Amazon - worth every penny for this job!)
Mine took another half quart after the 1 min run / 5 min wait.
This is from the workshop manual and shows up to 20mm (~3/4 inch) below the hole is an acceptable fluid level. Likely this allows for a quick "fill to the plug" during vehicle assembly then drops once the cooler & filter assembly is filled.
Ford Maverick Changing The Transmission Fluid on Your Hybrid Maverick (DIY Step By Step) 601466856_1161310252849892_8770075311644120304_n
Mavster Mechanic
Hybrid
The fluid for hybrid eCVT and EcoBoost is the same?
Is that correct?
