The Weatherman
Dean
KY
How much more difficult is applying a ceramic cost compared to a good hand wash/wax job?
A good deal, if done correctly. Significant front end prep and long drying time that needs to take place in specific environmental conditions.
jwilson
NJ
PENDING MAV XLT/Hybrid
A lot - and much easier to seriously mess it up. If it's not applied properly and within the right time frame, it can cure poorly and you end up with a worse looking finish that's VERY hard to correct.
I've gone the hybrid route - good wash & hybrid ceramic wax, then a hybrid spray wax (Turtle Wax Hybrid Solutions) with two 24hr apart coats. Then use TW's 3-in-1 spray detailer for quick cleans. I don't have the patience - or the steady hand and know-how - to do full ceramic.
Delzona
Tucson, AZ
A
Applying ceramic coating is about the same as applying a coat of wax. The thing with applying ceramic coating is the prep work. Any imperfections in your paint, swirl marks, chips, scratches need to be fixed before applying ceramic otherwise those imperfections are there for good. There's a lot of how videos on YouTube that explain how to use, apply, and take care of ceramic. When it comes to which product to use there's a lot to choose from, again a bit of research can help you make a decision. Personally, I like Adam's Polishes products and have had great results with.
TacoHolder
Phoenix AZ
Not Mav
I wanted to share some photos of my 2022 velocity blue Maverick with newly applied ceramic coat. It might be tough to see the difference the ceramic coat made with these photos, but results are truly incredible. The depth of paint and the glass like smoothness is something that stands out in person and the feel of the paint is special. This is my fourth vehicle with various brands of ceramic coat. I started with the most basic spray that might last a year, next level Avalon King, to finally the Mac daddy of them all System X “Max”. The difference between Avalon king and System X “max“ I would say look and feel they are similar Between the two. The key difference is System X has no restrictions cleaning products, or even cleaning techniques. The biggest difference is the lifetime guarantee ( as long as it is inspected by an authorized installer annuall). This process for the Maverick took roughly 24-28 hours on labor to complete. in my opinion, the best time to do apply this product is when a vehicle is new and no wax has to be removed along with very little paint correction. I basically only needed was little paint polishing and paint decontamination via Claybar, lastly wipe down thoroughly with rubbing alcohol. At this point, each panels has to have product applied in small sections evenly and wiped off. The cure time indicated 5 to 15 seconds but with my low humidity and cool temp’s I found closer to 60 seconds was correct. I find the most difficult part is to have the correct lighting to apply and remove to a perfect finish. I had enough product to do all exterior paint, plastic, wheels, and paint within the interior door jams. I also applied glass treatment on all windows.
I found I still had some paint flaws that are now in bedded for life. Please see attached photos and let me know your thoughts
recommendations for this treatment, you need really good if not great Lighting. This process should not be taken lightly and if any doubt hire a professional.
These pics need a NSFW warning. This is car porn.
Aherpa
Iowa
Edge, Maverick Lariat Hybrid
I can't find an installer around me and the manufacturer's site does not have an option to buy the product. How did you get a supply of the product?
Rodeoman74
Rodeoman74
Casey
Milliken, Co
2022 Maverick 2.0l Lariat
I first contacted SystemX regarding ceramic product after using the consumer grade product for the past few years. I had to provide some videos of paint correction process, application of product, and finished vehicles to become an authorized installer. I would say as many others have pointed out that many good products on the market. If you decide to use a professional the product should be top quality. If this is your first time Armor Shield is a good product at a reasonable price.
good luck
Aherpa
Iowa
good luck
Thank you for your kind attention.
Rodeoman74
Rodeoman74
Casey
Milliken, Co
Your right about the investment. I found a shop in Bowling Green Ky that does the Vets built there and other high end cars.
It’s going to be a ‘major’ investment, but I have an appointment 3wks from now.
Having a small bra of PPF and full body ceramic coat along with two font windows tint.
Told my to never ask me how much it cost. 🤣😂
I wanted to see how your ceramic coat turned out? Im excited to hear your thought on the process and results.
The Weatherman
Dean
KY
It was due to go in today for work next week, but I’m taking care of my 88yr old father and he is having to have a surgical procedure this week now.
I called last week to cancel. 🙁
We’ll see how things go, before I reschedule.
Rodeoman74
Rodeoman74
Casey
Milliken, Co
I completely understand, take care of dad….
Happy Holidays
tsled
Henderson NV
www.helibuilder.net
2022 Cactus Gray, 2.5L Hybrid, XLT Maverick
although, it is not as difficult as some might make you believe. There is a good possibility that you might have a few mistakes that you’ll have to live with. In my mind if it was a Lamborghini, Ferrari, or any other high priced vehicle I would have hired it completed. On the Maverick, some of the professional cost is just a lot to invest on a 20-37k vehicle.
I would suggest practice on your friends and family vehicles first to gain some experience. 😂😂😆.
if you determine that you are a protectionist I would go for it. Take you time on one panel at a time starting with panels that a flaw could be hidden or unnoticeable.
if you invest to have complete, I think the only way to go is lifetime guaranteed. No one what’s to have to reinvest every 5 years.
love to know what decision you make.
Ya, try your hand on your wife's car first.
Rodeoman74
Rodeoman74
Casey
Milliken, Co
possibly another household item such as a grill….if you add to a high heat appliance make sure you get ceramic rated for 1600 plus degrees.
Ford Maverick Ceramic Coating applied to my 2022 Maverick - pics 6ACD0E34-44D3-4B9D-B4A0-50E635802C44
TCK
Jetta Sportwagen
I am way too lazy to do all that (shoot- my Harley looks like I dug it up) it boy is that beautiful! I will be parking mine as far away from yours as I can to save myself the embarrassment ;) Excellent job on it.
Delzona
Tucson, AZ
I did my practice ceramic coating on my Road King Special's saddlebags and they turned out beautifully! I figured it would be a good place to practice since they're small and easily cleaned up if I made a mistake. I've since done the front fender and gas tank, along with doing my whole Sportster 72! Turned it was really easy to do.
Eagle11
Valley of the Sun
I plan on clay bar, and ceramic coating the Maverick. With the Cyber Orange, this should really make the color pop. Plus make it easy to clean.
