Best Switch solution for fog lights
Jeb_Bush_enjoyer
24 XL Maverick 84 GMC Sierra
I’m looking to install some hella fog lights on my 24xl and am wondering if there’s a close to OE style switch solution for fog lights on the maverick I don’t wanna use a ugly switch on such a new vehicle
EVH5150
Southern Vermont
As mentioned above, the F150 switch is the most OEM and elegant solution.
Another option is to get the trailer brake control lower dash panel, cut an insert out of textured plastic, and install a couple of Apielle lighted pushbuttons from Amazon. These will work great for your Hellas. I have this setup for my Diode Dynamic ditch lights and grille lights; I'm saving the already-installed F150 switch for when I can get a fog light setup to work with my Tremor lower valence.
Jeb_Bush_enjoyer
Jeb_Bush_enjoyer
Bobbyjallday
2023 ford maverick
Thanks my guy how hard was getting it to work?
You'll need forscan to get the switch to function but it's plug and play. 5 min install and 5 in forscan, definitely reference the thread linked above for the process but its very easy
twracing
Joseph
Richmond, VA
2005 Nissan Titan, 2022 Chevy Trailblazer RS
What is the part number for that housing?
Jeb_Bush_enjoyer
Jeb_Bush_enjoyer
What about the actual wiring looks a little complicated but not out of my ability my main concern is the voltage draw of the fog lights I want could a high draw cause issues
EVH5150
Southern Vermont
You need to buy the whole lower dash panel. I'll have to see if I can find the part number for you.
Thee BCM is shared with models that sometimes still utilize halogen foglights so capacity on each pin should be at least something like 55W.
Bobbyjallday
2023 ford maverick
I used pin 7 on the bcm as my trigger wire for a relay then have my spot lights drawing from a 20a fused circuit. I had the same concern about draw, I'm running like 180w though. like darnon said it should be fine to 55 or 65w
BlueSpec1
Gene
Column Cover - Ford (NZ6Z-2604459-BA)
