Bakflip MX4 just installed in my XLT
Daniel
Puerto Rico
2022 Maverick XLT
It really turned out to be what I wanted ! This Bakflip MX4 cover is really strong and seals very good. Today I drove through heavy rain and all I got inside was a couple of drops of water, but I noticed that the screw that holds the cover on right front was loose on the same side I found a bit of water so it may be that the case...
Ford Maverick Bakflip MX4 just installed in my XLT 20221001_111513
Ford Maverick Bakflip MX4 just installed in my XLT 20221001_111510
Ford Maverick Bakflip MX4 just installed in my XLT 20221001_111503
Ford Maverick Bakflip MX4 just installed in my XLT 20221001_111459
Maverstang
Miata; Maverick Lariat Hybrid
Nice! The flush mount makes for a really clean look.
What it’s the vertical height in the bed when the tonneau is closed? (Eg maximum cargo height)
fossil
ernie
ohio
Or maybe this gap. Should the stars align (get my order) I'd save a bit of the front foam weather seal to stuff in here.
photos borrowed from @Hizzy8122 and @Nighowl2000
Ford Maverick Bakflip MX4 just installed in my XLT hizzy8122
Ford Maverick Bakflip MX4 just installed in my XLT Nighowl2000
MRickDetroit
Rick
Detroit
Future Ford Maverick
That looks really good, thanks for posting photos, plan to get same on mine if I ever get built.
ford5
Kansas
2018 F150; 2018 Murano
Looks great. That is my first choice as well once I get mine.
Chris_G
NOVA
C-6 Corvette
Back in the day, @Realtruck had forum discounts. If the price was right, I might have to get one.
Hot Runr Guy
West Chicago, IL
To the OP, was there any "gap", side to side, that you noticed during installation? I'm think about adding a set of the TS Rails alongside the BakFlip, and have the option of snapping-in some Yakima or Thule crossbars when they would come in handy. My guess is that the extrusion is probably 1/16" thick per side, so is there a 1/8" to work with?
https://truxedo.com/elevate-ts-rails/2022/ford/maverick
HRG
MaverickCarAudio
Daniel
Puerto Rico
2022 Maverick XLT
Thanks, vertical is about 19" with the plastic bedliner. Painted bedliner should give an inch more
MaverickCarAudio
Daniel
Puerto Rico
2022 Maverick XLT
HRG
Well, installation seemed to be very tight, it really seals very good. I'm sure the loose bolt in the front allowed tje water to come in. I will test it tonight with a waterhose
kenswebdesign
Ken
Largo, FL
2022 Ford Maverick Hybrid XLT Luxury Package, 360
Yes, I have the same cover and love it. Florida torrential downpours don't get in to bed once I did put a small piece of the foam right where that finger is pointing and ALSO a similar small piece of foam down at the tailgate end where there was a similar small gap...probably like 1/8 x 1/4" .... after that I barely get a drop of water in there even when it is pouring.
