Deleted member 9167
Guest
Recently swapped my Truxedo Pro X15 soft roll up cover for a hard folding cover (which BTW you can buy HERE).
My only complaint with the X15 was that I had to open the cover every time I wanted to close the tailgate. Enough of an annoyance to spend $1000 on the BAKFlip... But I really did like the X15 for what it was... low cost, low profile, and easy to use.
The BAKFlip goes on easy and folds "out of the way" against the rear window, which blocks the view completely. This cover doesn't come off as easy as the X15, but two thumbscrews on either side and it's off in a minute or two. Weighs about ~50lbs and came preassembled. I don't have any pics during the install, but its the same L rails and clamps as any other cover. Very happy with this cover and it will support ~400lbs of weight on the top according to BAK. And I won't see any flutter in the rear view window like I did with the X15.
Cover shown in the most "open" position with small child lounging at baseball practice. There are three foam blocks that rest against the back window that are stuck on the underside of the cover.
