Gullzway
OK
1968 Ford Mustang Fastback
Chandonnet
Chandonnet
Brookline NH
What was the wiring like that came out of the mirror and did you supply your own wire from the mirror to fuse panel?
Came with just a few inches of wire. I supplied the rest of the wire and fuse taps.
greenweever
Peterbuilt
Any picture of routing the wires under the headliner? Was it as simple as wedging in there, or did you literally have to remove part of the headliner and re-adhere it?
Chandonnet
Chandonnet
Brookline NH
Nope, just loosened up the visor and tucked them under
BoxxerDad@50
Kip
Lees Summit MO
MY25 XLT BAP XLT HYBRID SOLD MY 2023 XLT hybrid 2023 Lariat,MY22XLT
Just finished up installing my auto-dimming mirror. Unfortunately I jumped the gun and ordered mine used off eBay a few days before someone found the cheap Kia mirror online but oh well. Was just under $60 shipped. Has auto dim, homelink, and a hidden compass as a bonus.
For power I ran 3 wires from the mirror down to the fuse box in the passenger footwell. For switched power I tapped into the #3 slot, and for constant I tapped into the #20 slot. For the ground I just used a ring terminal and put it on the bolt holding down the fuse panel.
I personally wanted my homelink to be on a constant circuit. I know some say someone can break into your car and open your garage but I park in the garage when Im home anyways. If you want to you can wire both of them to circuit 3 and only need to use one fuse tap.
Homelink is programmed and works perfectly as does the auto dimming feature. Just need to calibrate the compass and all will be good to go.
Awesome Brian
Thanks for the share
Rob Cactus Gray
Robert
Sierra Vista AZ
11 Prius
what amp fuses did you use? Standard 12 gauge wire? Thanks!
LARIATBLACKFUTURE
Nebraska
22 Ram 1500
Nope, not me. Auto mirrors are not near as dark as manual.
Nope, not me. Way too much glare from auto mirrors and they are not as darkening as manual.
Adrian
Adrian
Does the mirror fit right on the Maverick's windshield original mirror holder?
Dad
1. Does anyone know any alternatives to the Kia mirror that have dimming, Homelink and the compass? (that Kia one is impossible to fine), and 2) How tough are the wires to conceal?
Since the Mav is based on the Ford Escape, I'm wondering if the mirror will easily adapt to the Maverick. If so, I would think it would be cheaper than the KIA. I haven't done any research as yet, as I'm still awaiting delivery. Sort of takes away from the urgency.
clavicus
Dad
clavicus
Yipes! I know, cheaper than the $250 and up price I've seen for new.
I think you can consider the exact model of mirror as totally interchangeable between car makes and models since they are kind of a "dumb" hardware, they generally do not communicate with the vehicle they just need power. So you can really use any of them it seems. From what people have said, the mirror mounts are standardized (is that generally true?) so as long as the mirror doesn't have an especially stubby or aggressively up-ward angle of the arm that would contact the BLIS plastic cover above, any of them should work.
MLowe05
GA
They should be interchangeable. It's not like Ford produces their own.. these are all made by just a few manufacturers, Gentex being a huge one.
Dad
Thanks for the information!
