Are my wipers binding or is this normal?
PanchoBarrancas
Jalisco, Mexico
2022 Maverick 2.0 AWD
Rainy season in my area has just begun and with that I've noticed that the wipers on my truck seem to jerk and thump at the end of their downward motion - see video below. This only happens in the variable speed mode, the continuous high speed modes have a smooth motion. I had never experienced jerkiness like that from any other cars I've driven, is this normal or should I go get it checked out at the dealer?
Nomadikhan
Stephen
Ohio
88 Daytona Shelby Z, 07 Yaris, 22 Maverick AWD 4K
Yep, not normal. Mine are smooth action, and slowly tuck away when off. Not a single noise, clunk, or anything like what you have there.
Bad Actor
Christopher
SE Missouri
01 Ranger XLT, 73 Mustang Base, 02 Toyota Camry
Looks like passenger side is hitting windshield molding. I bet they put the wipers on wrong. The longer one (22") goes on driver side, shorter one (21") goes on passenger side.
Dochatley
Jerry
Dallas
Ford Explorer, 2024 Maverick Hybrid
Try swapping sides. Passenger side looks long as they have said.
PanchoBarrancas
PanchoBarrancas
Jalisco, Mexico
Thank you all for your input. The longer blade is correctly installed in the driver's side, and after checking the motion from outside neither blade is hitting anything in there travel. Seems like the wiper motors or gears are at fault here.
Ford Motor Company
Official Ford Account
Dearborn, mi
Hello there! Could you please send over a private message with your VIN and the name/location of your local Ford dealer? I would like to get to the bottom of your Maverick's wiper concerns!
Drew
Ford Social Media Team
Milous
WA State
2022 XLT Alto Blu, LUX, Sunroof, delivered 3/18/22
Most likely a bad wiper motor.
Monty1719
Forte GT, Prius Prime, Forte GT-line, Maverick awd
Mine is exactly the same. I am pretty sure we have a build of road oils/grime etc right at the bottom edge of where the wipers stop and go the other direction during normal wiper operation. When the wiper is intermittent mode like that it drops just below the line it stops at when in normal operation. I am going to trying cleaning my glass and blades tonight with alcohol in the area it chatters like that to see if it fixes it.
Monty1719
cleaned my wiper park area quickly and the studder is half gone. I think I need to try cleaning it and the blades better
Strobe
OH
2022 Ford Maverick, 2013 BMW M3
I have had this issue for a few months on my Maverick as well. it’s incredibly annoying as it chirps and squeaks sometimes. It only happens with the wipers on intermittent settings. Low or high speed continuous setting works fine, no issue and single wipe no issue either. Only happens when the blades are trying to park in the slightly up position from using the intermittent settings.
I’ve cleaned the windshield several times, tried some slick drying aid topper I use on the paint too, and nothing has fixed it. Cleaned the blades once as well. Use the same cleaning products on my other cars with no issues. Next step I’m going to try is compounding/polishing the windshield to make sure nothing is on it somehow causing this.
