Aherpa
Iowa
Edge, Maverick Lariat Hybrid
My wife was digging around in the unlit glove box and asked "is there a light?". I briefly thought about a battery operated stick-on but I wanted something better so I went looking. Sorry I don't have 'in progress' pictures. It just wasn't something I thought to do at the time. I will explain it the best I can.
I bought a KIA glove box wiring and switch from Walmart and added a brighter light from Amazon.
https://www.walmart.com/ip/Car-Glov...Ix35-Tucson-Sundries-Box-Lighting/10966368452
https://www.amazon.com/dp/B09BKGXKRD?ref=ppx_yo2ov_dt_b_fed_asin_title
To make things easier, I removed the glove box and it's frame from the truck. The Torx nuts are long and have a fine thread, they also make an odd 'crunchy' sound when I unscrewed them. Anyway. . .
Once I got the frame out, I looked for how to place the holes for the light and the switch. I noticed that the dash had 'dibs' on the forward part of the upper shelf I wanted to use, which reduced the amount of space I could use. So, I drew a line on that shelf connecting the back of the top two mounts to represent that part of the dash that hangs down and found I had ample room for the light. Be careful when cutting because little nicks will be visible if the light or switch cannot cover them. Also cut small and test fit each cut, you will get there quicker than you think and a tight fit is better than a rattle.
I used a Dremel tool and a box opener to cut out the holes after making experimental cuts in cereal boxes to get the fit perfect. The Dremel to make the initial through cuts and the box knife to trim to final size.
Mounting the switch was trickier (it is smaller) and I found I had to mount it close to the left hand top mount so it had ample depth to not interfere with that part of the dash that hangs down because that would be highly visible. I also mounted it low and very close to the shelf.
The switch is 'keyed', that is, it has little wings molded into it. To make it easier, and minimize my chances of screwing up the face plastic, I trimmed off those 'wings' so I only had a small rectangle to cut out.
The power leads from the wiring harness for the glove box light, were not long enough so I extended them by using wires with insulated spade connectors, routed them to the BCM and secured them with zip ties to the wiring already there. One wire went to the ground stud of the BCM and the other tied into the same wire I used to power the auto dimming mirror that I installed (fuse #3).
Ford Maverick Adding Light / LIghting for glove box - DIY install 1732198954703-mx
Ford Maverick Adding Light / LIghting for glove box - DIY install 1732198895960-bj
Dad
This is a great modification and highly needed. I commend you on the neat job. Not easy when you're pioneering an install such as this. I tried the battery operated small LED approach and while adequate, invariably, just when you need it , the battery light goes dead. This is a much better solution. Thanks for posting.
rknrbt
bob
Pleasant Valley, Mo
2019 Ford Fusion
I wonder if it will work when the battery is in saver mode. Courtesy lights don't.
swtiming8
Wayne
Mishawaka, Indiana
Focus
I guess I have to ask how many times have you or the wife gone searching in the glove box to justify the effort and expense of a light? Honestly in the time I have owned my Maverick I have never went on a scavenger hunt. There’s a reason Ford did not include one from the factory. But if it makes the wife happy I guess it is worth the hassle.
Toddman45
St. Louis, MO
Nice work, what wires did you tap for power?
In a pinch, I have found that the dome/map light does a pretty good job of Illuminating the glove box.
Ford Maverick Adding Light / LIghting for glove box - DIY install 20241121_102139
Toddman45
St. Louis, MO
@asylis what wires did you tap for power?
flyswatter
Macon GA
2024 Ford Maverick Lariat, 2020 Lincoln MKZ
Awesome work, though I'll stick with the flashlight in the center console.
Tim d
Alpena
Ram
Good job! On a related note, we had a hard time opening our glove box recently, it was " stuck" we eventually got it open and closed and my wife found a round plastic washer about the size of a quarter on the floor.any idea where that goes?
14mikey14
Marshall, MI
2024 Ford Maverick XLT HPR
Thanks for posting this and the straightforward write up.
Picture??
Vickram
Dearborn Michigan
Blk 23 Mav Lariat , 09 Escape ,72 honda 350 cycle
I put a motion sensor PUCK LIGHT in my glove box. I just stuck it to the left side of the box .It works just fine , it comes on when I open the box. The golve box doesn't get used that frequently . Got a 4pk. on Amazon for $10.00 . I attached the other three lights to the underside on my tri -fold bed cover , two , back by the tailgate and one in the middle section, again not a lot of action in the bed . Let me be the first to comment .THAT IS WHAT SHE SAID .
