700+ Miles Per Tank Club
Wnbasac
Louie
Calif
Honda CR-V & firebird T/A
You are right there, good work. Did you have to change driving habits very much?
I am getting very good driving highway and pulling down good numbers.
I can get 65mpg on a 20m highway trip, with ~8m electric miles. I am going to try to pull down a 700mpt with more highway miles and not using eco mode.
not really but everyone recommends using ECO Mode? I haven't used but i'm going to try it out
Mach 1
Randy
Spicewood
2022 Maverick Lariat Hybrid sold 2024 mav hybrid 2018 F150 Lariat 3.5 ECO
Its slow with pretty good power loss, a good key is force e mode as often as possible, or as traffic allows.
I am relearning how to drive highway and getting some good numbers now. I am good to try to hit 700mpt with more highway and less ECO mode driving.
Also got called out by the ECOBOOSTS guys to try to get 500mpt E mode.
Scupking
CT
2025 Ford Maverick XLT Hybrid
I might be in this club. Every time I drive my miles until empty keeps going up instead of down. I'm impressed!
Mach 1
Randy
Spicewood
That is SO cool when the computer has to recalculate, then you look down and damn i have more miles till empty, its like getting free stuff.
When i see that, it just makes me to want to drive even more efficiently.
Mach 1
Randy
Spicewood
Heres the latest tank, $2.96=RUG. Its a personal best on the mpt=721m, still getting better driving. Less AC use here, temps are coming down.
Ford Maverick 700+ Miles Per Tank Club 20220909_124926
Wnbasac
Louie
Calif
I'm getting close here’s my 1st. Full tank down but I tapped out. The 2nd. Time around I’ll use Eco Mode…..I’m in a Slow speed Pursuit of the Elusive 700 Club
Ford Maverick 700+ Miles Per Tank Club 2573FB90-FD05-4099-A881-AEB01A992D3A
Mach 1
Randy
Spicewood
Wn, that is so close, its crazy what potential these Mavs have for FE. Not very many members have got those numbers.
I have been using Normal mode more often. I have driving highway more during my tanks.
MaverickShark
MaverickShark
Sal
San Jose, CA
Maverick XLT Hybrid 2022 Mitsubishi Outlander 2017
Should I push my luck to make it to 800, or should I just fill up? This is definitely the best tank I've had.
Ford Maverick 700+ Miles Per Tank Club 20220916_151912
Mach 1
Randy
Spicewood
Wow
Damn, that is a 800mpt, you definitely know how to fill the tank. 15g? 16g?
There was only 1 other guy that did 800, but he put 16g or 17g in.
GPSMan
Many
Seems there is quite a lot of variability in how many gallons you can pump in. Example "burp" the truck to get more air out and more fuel in. MPG should always be the key metric. 50+ MPG is very doable. In city, I'm getting 55 to 57 MPG day after day.
Mach 1
Randy
Spicewood
This one is inconsistant as well, however it seems like the fuel pump. Sometimes i can put 13.5 in real easy other times i can go 14 easily. I have never put over 15 in once, then got chicken
Hardening2753
Ford Maverick Hybrid
Heres a couple, but you still got me beat..i only get 53mpg. I got 3 of 4 last tanks of 700m. Its tough getting these. How much fuel you putting in tank, i only 13.5g?
One simple trick to piss off Musk..
MaverickShark
MaverickShark
Sal
San Jose, CA
The most I have pumped was 14.021 gal. I will only do 2 or 3 clicks.
Mach 1
Randy
Spicewood
Shark, thx, sometimes i do first, others 2,3 clicks, and of course i have to know what my options are, although when overfilling i cringe while filling.
No more ever then 15g once just for data, although talked to guys put alot more in then that.
GPSMan
Many
So the online "horror stories" usually revolve around getting fuel in the Evap charcoal canister. I saw a video online with the Mav up on a rack. If correctly ID'd the evap canister is UNDER the fuel tank (as in lower down) so I don't see how filling up as high as you want would matter in this set-up.
