2025 Hybrid Gear Ratios & HF45 Transaxle Technical Info
My 2025 paperwork, window sticker, etc. says:
  • 2025 FWD with 2.91 Final Drive Ratio
    Votes: 0 0.0%
  • Total voters
SafetyGuy
Andy
Manitoba
I love the fact that you are able to figure out thes ratios, etc and have the equipment to do it.
A bit over my head but when I get some time I do want to sit down, take my time and try to understand at least some of it!
Interesting stuff.
Andy
SafetyGuy
Andy
Manitoba
Ford Maverick 2025 Hybrid Gear Ratios & HF45 Transaxle Technical Info Screenshot_20250522_075750_Samsung Notes
Good day
So, I finally sat down and had another look at my truck e-manual and verified my truck has a 3.37 rear end.
I did the survey, now that I had something to go on.
Cheers
Andy
heady
MI
'25 Lariat
I put my vote in on the 3.37 final for the 2025 AWD w/ the HF55 as I just got done looking through all the changes from HF45 to HF55. Starting with the differential helical gear, it was changed from 61 teeth (HF45) to 64 teeth, and the differential driver gear on the transfer shaft changed from a 21 tooth to a 19 tooth:
HF45 Differential helical:
Ford Maverick 2025 Hybrid Gear Ratios & HF45 Transaxle Technical Info shirina-29-85-mm-16-krepezhnyh-otverstiy-1-800x800
HF55 64 tooth helical:
Ford Maverick 2025 Hybrid Gear Ratios & HF45 Transaxle Technical Info shirina-34-70-mm-16-krepezhnyh-otverstiy-2-800x800
HF45 Transfer gear 21/83/93:
Ford Maverick 2025 Hybrid Gear Ratios & HF45 Transaxle Technical Info nar-165-85-mm-snyato-s-novyh-transmissiy-3-800x800
HF55 19/89 Transfer gear:
Ford Maverick 2025 Hybrid Gear Ratios & HF45 Transaxle Technical Info rnya-89-zubev-nar-149-75-mm-bez-nasechek-3-800x800
HF45 Traction motor gear 26T:
Ford Maverick 2025 Hybrid Gear Ratios & HF45 Transaxle Technical Info ev-nar-50-70-mm-27-shlitsev-nar-27-85-mm-3-800x800
HF55 Traction motor gear 27T:
Ford Maverick 2025 Hybrid Gear Ratios & HF45 Transaxle Technical Info ev-nar-49-25-mm-27-shlitsev-nar-27-85-mm-3-800x800
HF45 Planetary Ring output pinion 59T:
Ford Maverick 2025 Hybrid Gear Ratios & HF45 Transaxle Technical Info m-th-17-40-mm-snyato-s-novyh-transmissiy-3-800x800
HF55 Planetary output pinion 61T:
Ford Maverick 2025 Hybrid Gear Ratios & HF45 Transaxle Technical Info 18-7f342-bb-7603911-61-zub-nar-105-85-mm-2-800x800
HF45 Planetary Set 86R/26P/34S w/oil pump drive gear:
Ford Maverick 2025 Hybrid Gear Ratios & HF45 Transaxle Technical Info aya-vysota-152-mm-21-shlits-nar-21-80-mm-2-800x800
HF55 Planetary set 86R/26P/34S w/o oil pump drive gear (electric pump):
Ford Maverick 2025 Hybrid Gear Ratios & HF45 Transaxle Technical Info aya-vysota-152-mm-21-shlits-nar-21-80-mm-3-800x800
Old HF35 was similar, but with a 23/59 (2.57) final set. 10.39 HF45 traction motor to wheels total reduction, 11.10 HF55 traction motor to wheels. HF45 4.086 (2.91 final) total reduction planetary ring to wheels, HF55 4.915 (3.37 final) total reduction planetary ring to wheels.
Scupking
CT
2025 Ford Maverick XLT Hybrid
Since eCVT transmissions are strong, simple and reliable why don’t they just use them in all their vehicles?
The Real Maverick
The Real Maverick
Jack
People 'like' shift shock.
There's even a button to turn it on in the hybrid Maverick.
LSchicago
Lloyd
IL
My 25 AWD hybrid has code 33 on the door jamb, which is a 3.37. Older hybrids had code 29 which is the 2.91 final drive.
inline_five
2023 Hybrid XLT
The HF55 looks to have some beefed up components vs the HF45 for sure.
I will say it would be interesting to buy a 22-24 hybrid in ten years or so when they get cheapish and really beat on it towing wise and see what it can sustain long term.
heady
MI
'25 Lariat
Likely the manufacturing cost, not only is the transmission itself probably more expensive than making a clutch pack automatic, you also need at least some little battery or ultracapacitor to make it work. Now that copper is going to increase in price ~50% and rare earth magnets likely also become more rare/expensive in the US, the price difference to manufacture will probably increase even further in this market. Plus, you lose some of the efficiency advantages of the overall powertrain if you couple it to a more powerful non-Atkinson engine, although you can make an efficient and power focused combination by using a Miller cycle forced induction engine which combines the benefits of Atkinson and turbo/supercharger engines.
Mine doesn't simulate shifting in sport mode that I can tell
Others in 25MY have reported it does the same as prior years.
Try it again, radio off.
They fire off pretty quick if really pressing the Go pedal, and it's smooth still since not an actual shift. But even going slow can be noticed.
This snippet shows the torque when it's done, obtained by changing the ICE and generator/gearing motor RPMs.
Ford Maverick 2025 Hybrid Gear Ratios & HF45 Transaxle Technical Info 1752165270605-tu
The Real Maverick
The Real Maverick
Jack
So does Sport Mode give hybrids a 5-speed, 6-speed, or 8-speed?
You're right - appears to be pretty chintzy 5 speed, unless letting my foot off would have gotten me a nice 6th over-drive gear - maybe a 7th at 80 mph?
Without the downshifts though, it just misses something.
(thinking about a post that said their hybrid was giving rough shifts, perhaps mimic a manual mis-shift, oops wanted 3rd got 5th!)
