2024 XLT - Cluster Lens Etched
tysonbisme
Tyson B
24' XLT EB, CGM, SIB
A user has been marked as "ignored" on my end for improper engagement on a public forum. Zero helpful comment came from him - so if you (a scroller) see posts where it looks like I am talking to myself... I was in fact, not.- 🤣
clos0791
Carlos
Maverick Lariat, Alto Blue AWD
Thanks for the words of encouragement!
I'll see what PlastX can do today. Will be removing the whole cluster to test.
How hard is it to remove the whole cluster? Curious, just in case. In my Jeep Wrangler, you have to dismantle almost the entire dash. Thanks.
tysonbisme
Tyson B
Relatively simple... but you will break the 2 clips along the side of the cluster surround panel. it is inevitable, unless you're Elastigirl or her male equivalent and can push the clips "in" as you're pulling out. You;'ll likely damage more if you do it that way, however.
Here's a good YouTube link...
tysonbisme
Tyson B
Hey everyone..
Spent a lil bit of time on this today with Meguiar's PlastX. A few notes to know about if you'd like to try this -
1. Use SMALL... and I mean small... like the size of a pea - dabs of this in small sections of the cluster as you move along it.
2. Use brand new, clean microfibers. It does not matter what kind they are as long as they are relatively soft and you will not get the fine scratches out anyways - in fact, you'll probably cause more than you had before.
3. Work in circular motions, then go back over it with straight up and down. As mentioned before, the goal here on my end was to get rid of the etching, not necessarily reducing scratches, etc. Someone more versed in detailing will need to chime in on that method here
4. You want the product to basically end up "almost" clear before wiping it off. The more "white" you see, the more haze will be left over
I am not perfect at this, but I think I got this to an acceptable level of cleanup before @Ford Motor Company responds with a good reason that the new cluster lenses are only available for purchase on Lariat models. I think I speak for all of us - we'd like to be able to get these regardless... They are very, VERY soft plastic and replacements are relatively simple... if they were available.
Before picture(s) are in the original post, here are some afters.
Ford Maverick 2024 XLT - Cluster Lens Etched IMG_0587
Ford Maverick 2024 XLT - Cluster Lens Etched IMG_0588
Ford Maverick 2024 XLT - Cluster Lens Etched IMG_0589
Ford Maverick 2024 XLT - Cluster Lens Etched IMG_0590
Ford Maverick 2024 XLT - Cluster Lens Etched IMG_0591
Carlitos_92
Nice work!!! Glad it worked out pretty well.
tysonbisme
Tyson B
I did what I was comfortable with. going further just means more plastic gets eaten away. It is far from perfect, but I did not expect perfect. I just wanted the etch marks out of here.
It's as good as it's going to get without the new cluster lenses being available (yet, wink wink Ford).
You've been super supportive with this, thanks a bunch!
Perfectly acceptable.
Are you still planning on replacing if it come becomes available or just wait and see?
tysonbisme
Tyson B
Are you still planning on replacing if it come becomes available?
Absolutely, 100%. to me, it's acceptable for now. Way, way better than what i started with.
I'll likely order 2 lenses once they become available, because why not.
1929
Lake Michigan
Ford Maverick XLT Hybrid
Hey everyone..
Impressed with your results.
Why the heck are replacement lens not available for XL and XLT?
tysonbisme
Tyson B
i have no idea. Probably one of the dumbest things I’ve seen… and this is my first ford so on a part that simple - it’s pretty clear what their goal is. Make parts available for the “high rollers”, and us “peasants” with lower tiered models have to replace the trucks sooner.
hopefully they decide to offer the lenses for XL / XLT… I truly cannot find a good reason they aren’t offered.
thanks for the positive notes on the results!
Just a wild guess.
Manufacturer's Supply output.
I am thinking, they build twice as many xl's and xlt's together than lariats.
The manufacturer can only keep up with XL and XLT for assembly line use. The Lariat having a different lens being a lower sales volume model there is a surplus of lariat's instrument len's.
Good luck.
tysonbisme
Tyson B
Just a wild guess.
Good luck.
pretty solid guess, if you ask me.
However… I think it should be available regardless. Is the cluster different on the 25s now? Perhaps we will see XL and XLT 22-24 lenses available soon.
Ford is not going to shut down an assembly line because they are out of a critical part, because it's being stocked as Surplus parts.
Does not make business sense.
Customers have had their trucks in the shop for crash repair and have been waiting weeks for a critical power steering module part.
All the steering modules are being dedicated to the assembly line to produce trucks for consumers.
tysonbisme
Tyson B
we don’t need them to shut plants down for a single cluster lens - I would wait a month for one to come in. I think we just want the ability to order it regardless… that’s the goal here (at least on my end)
tysonbisme
Tyson B
Shoot, even 3 months id wait. The option to purchase it at all is what im looking for.
