2023 XL/XLT PSA - No ambient lighting
bbhaag
I understand that. I was just explaining my original confusion on what the topic was about is all.
I thought they didn’t have ambient in the way the order guide says and they don’t. Only Lariats do. The others thought the opposite. They’re both correct, just referring to different things. I was just explaining my original confusion
Sounds good man. So now that we got to the bottom of the naming confusion lets get back to helping the OP add some ambient lighting to the center console of his 23MY XLT.(y):)
Executech
Matthew
Ford maverick
Can anyone with the light take a picture of your layout? I'd like to try and get the part numbers from both the bulb and the console.
When you get a chance can you pull out the console and snap a picture? It doesn't require any tools, pulls straight out.
I have a 22 xlt hybrid and I have ambient lighting.
Ford Maverick 2023 XL/XLT PSA  - No ambient lighting F439AD4A-A292-4D4F-89A2-8CD35CEB29DD
JerseyMike
Belmar NJ
2019 Mazda 3
Well I guess now that Ford did what they do again, I'll just plug one of these into the unused USB C or a lighter adapter. And I'll put a bonus one in the back too
Ford Maverick 2023 XL/XLT PSA  - No ambient lighting Screenshot_20230114_165445_Amazon Shopping
bbhaag
@Executech how did you get the panel to come down? I tried just sliding it forward like the OP suggested but had no luck. Are there some clips or screws holding it in place?
Executech
Matthew
Ford maverick
I haven't seen this posted, but compared to the 2022, my 2023 does not have the bulb for the center console or the icon in the screen for ambientCan anyone with the light take a picture of your layout? I'd like to try and get the part numbers from both the bulb and the console.
The best way I can explain it is I pulled at an angle between down and toward myself. The brackets appear to be angled.
NoVaJimmy
KCMO
Lexus GX 460
Are some of you misinformed?
since when was the blue ambient lighting included with xlt? It’s a lariat feature
Nah, I have it on my XL. On my 2022 it was defaulted to off. I had to turn it on in the settings.
Ford Maverick 2023 XL/XLT PSA  - No ambient lighting IMG-0280.JPG
TedTX
Ted
San Antonio TX
Ok this is bugging me, how do you all get that plastic tray loose? I have tried and it seem really stuck in place. Are the two bolts under it important. Do you yank straight down or something?
bbhaag
Thanks! I'll try again using your suggestion and see if I can get it to loosen up.
blackb13
Looks like part number is the same, they just updated the "d" to an "e." Also, my part is 3 months newer. I will have to wait until Monday to see what the parts department says.
Did you happen to notice a part number on the light itself?
Also, since there isn't a setting in the infotainment, I wonder if there is an option to enable it in Forscan...hmm.
blackb13
Right thumb in the cigarette lighter, left thumb along the usb port, pretend you're going to strangle it and pull towards the shift dial. There are 4 clips that hold it in. No screws.
TedTX
Ted
San Antonio TX
Nope, even imagined my older sister in middle school mode of evil to get enough rage to strangle it hard! No deal.
blackb13
😂 Use a plastic pry tool then. Start with one side (driver or passenger) and go from there.
volksnuts
Katy,TX
Maverick Lariat HPR
Dang I had my XLT for 6 months and didn’t know it had that feature
Bummer that it was defaulted to off
I could have used it
On the XL/XLT it seems to frequently revert to off. I suspect whenever the infotainment got updated.
PlantMan
Berwyn Heights, Maryland
2017 F-250 4WD crew 8' bed; 2022 Maverick XL AWD
The console downlighting had defaulted to off in my XL. I didn't even know it was there. I learn something every day.
