- First Name
- Jefferson
- Sep 20, 2022
- Metro Detroit
- 2020 Ford Fusion SE 2.0 AWD
- Engine
- 2.0L EcoBoost
- Banned
- #151
Wow. Another recall. Color me shocked.
My Lariat built 12-12-22 has the problem. I went to hookup a trailer and the running lights did not work or the 7 plug terminal.With the dates listed, EVERY MY23 Maverick produced up to February 10th with the tow package is affected by the recall.
Does your Mav have the 4K Tow Package?My Lariat built 12-12-22 has the problem. I went to hookup a trailer and the running lights did not work or the 7 plug terminal.
Yes, I have the tow package and off road package.Does your Mav have the 4K Tow Package?
I tested the 4 pin termianl and the running light does not work and the 7 pin no power to it.Yes, I have the tow package and off road package.
My Lariat with 4k package, the 4 pin is missing power on the running light and the 7 pin has no power to it, checked with pin tester.It did on mine, the combo connector is fed by 1 harness. The split incurs inside the connector.
HRG
maybe the bean counters will do some cost vs risk analysis ..probably not...let's see spend a minute testing a plug or issue recalls and have to pony up for the fix later on and add to the poor PR. Wonder which one is going to cost more?Seriously, how does a truck get through an assembly line without someone plugging a tester into the trailer ports?!
Humans make mistakes and forget to plug things in, damage wires, or otherwise screw things up.
And this is just the running lights. Imagine if the supplier "forgot" the wire for the trailer brakes.
This is something that would've been caught with a test that would take <1 minute on an assembly line. For them to miss it for almost three months is inexcusable! Really makes me wonder what else they might have missed that a quick check would've caught.
I tested my 4 pin and the running light is not powered and the 7 pin has no power to any pin. I have the 4k packageI took my little 4-pin trailer tester on to my 1/12/23 build. It works fine, as others have stated...and I was in the middle of this period. Too bad Ford didn't specify the 7-pin was the problem, but I am pretty sure it is NOT a 4-pin problem.
I would imagine that a fair amount of this recall cost will be pushed over to the harness vendor, who delivered non-conforming product.maybe the bean counters will do some cost vs risk analysis ..probably not...let's see spend a minute testing a plug or issue recalls and have to pony up for the fix later on and add to the poor PR. Wonder which one is going to cost more?
So, does this suggest that the wiring harness on the AWD with 4K is different than the wiring harness on all the other vehicles? I've still not found any Mav except the AWD with 4K on the recall list.I tested my 4 pin and the running light is not powered and the 7 pin has no power to any pin. I have the 4k package
EDIT: wouldn't it make sense that a different wiring harness would be used since the 4K has trailer brake electricals?
I wouldn't know. I plan to go to my dealer and see what they have planned. I need my trailer lights functioning.So, does this suggest that the wiring harness on the AWD with 4K is different than the wiring harness on all the other vehicles? I've still not found any Mav except the AWD with 4K on the recall list.
4K package is the only way to get the 7-pin connector.Does your Mav have the 4K Tow Package?
So this is kind of interesting. Once I downloaded the 13,586 page service manual, I could use the information provided in my repair ticket, and pinpoint where my repair took place. This is an under-hood harness (#14290), the missing wire was from splice # S122 to the BJB (Battery Junction Box) connector # C1035A, missing pin #33.EDIT: wouldn't it make sense that a different wiring harness would be used since the 4K has trailer brake electricals?
