- May 29, 2024
- Central Nevada & Utah
- Maverick XLT Hybrid
- Engine
- 2.5L Hybrid
And if indeed the Maverick hybrid fuel tank is lacking an internal bladder. Any type of "small" leak is exacerbated by the positive pressure within the fuel tank.Thank you - that definitely helps me understand the Hybrid EVAP system better!
I was mistaking the “hiss” of the gas cap to the “hiss” of opening a jar of pickles (negative vacuum pressure).
Instead it is the “hiss” of positive pressure like opening the cap on the coolant system. And that would explain why the gas tank hose/clamp leaks are more common on the Hybrid.
You have just experienced the mind of an EB owner becoming enlightenedThank you for explaining & hope I did not waste too much forum time on this Hybrid basic!
