- First Name
- Mike
- May 3, 2024
- KC Metro area
- 2005 Toyota RAV4, 2024 XLT Hybrid
- Engine
- 2.5L Hybrid
If the fuel level is above the intake port - you auto-block fumes from escaping.I discovered the exact same issue on my 2022 XLT this week. My son has been driving the vehicle and always parks outside here in Arizona. He came home for the holidays and parked in our garage and we noticed a strong smell of gasoline. I have older vehicles in a motorcycle in the garage so figured it was one of those. After an extensive search, I realized it was fuel leak leaking out of the inlet of the tank on the Maverick. I checked the hose clamp, which was tight. From what I can tell it looks like it’s leaking from the white or rubber gasket between the flange and the tank. I am curious if that flange is something that can be replaced or is attached to the tank? I have included some pictures that were taken after I cleaned the area up. There was black gunk around the white flange and a stream of fuel leaking down the bottom of the tank We were going to take it into the dealer but if they’re gonna charge me 1100 bucks for a new tank and I might as well put it on myself. I am not a mechanic, but I can’t understand why you would put a fuel inlet in the middle of a tank. Every tank I’ve seen has the inlet on the top. This of course, makes it difficult to attach the hose, but makes much more sense to help prevent leaks.
Well, except the minor surface area of the fill tube.
Where the charcoal canister is attached.
