2.5L Hybrid - Change to 5W-30 oil
Master Blaster
Master
Toronto
23 Maverick Lariat Hybrid
"OP is ignorant on hybrid........."
Wow, did you get your information from God, or maybe Ford himself? Very pejorative comment, there is enough in this forum already. HTHS is a function of oil, and consequently "thickness". Anyone who is educated in tribology will tell you that said "thickness" is a major factor in wear, metal-on-metal. XW-30 is always going to reduce wear, over a 20 weight, which is a requirement of EPA . New designs which use different bearing/driveshaft clearances, etc. can use 20 and get away with it. The Ford L5 Duratec, while optimized for hybrid use, is an old cast design and will benefit with 30 weight oil.
XW-30 is fine if you can actually get it there. Its absolutely useless if you can't. Unlike overheated race engines, lubrication in the Hybrid is all about the cold engine numbers, and the hot ones are just an edge case. Shear strength is completely irrelevant when there is no oil there to shear. And while thickness is a common side-effect of getting sufficient shear strength, its side-effect. The shear strength in the Hybrid comes from using the better long-chain oil molecules that are in the mandatory synthetic oil.
710-oil-614
Cal
2025 Hybrid AWD Lariat
My neighbor upgraded her solar batteries last Nivember. I purchased her old 16 6v 400amp AGM for $400 total. They are five years old and were abused. They have all seen noco maintainers and are holding at 6.4 volts, some for weeks. Game plan is lights and 2 freezers in garage plus well (or at least fill pressure tank from 1250 gallon surface tank filled by solar well pump during day). Also possibly separate from garage power for fans lights etc in a greenhouse. Have agreement with her independent solar installer for additional batteries if in decent shape to buy at scrap plus $6-$8. Will hook these up to inverter and load test to see what I have to work with. One of her batteries only saw service for 8 months but was paired with 7 survivors in a 48v string. MSRP of those 123 lb puppies is right at $700.
That’s awesome! I would love a full PV array but it’s cost prohibitive currently. I think having solar as a supplemental source and not tying into your main panel and local grid is the way to go.
If the electric grid goes down I don’t expect my solar to maintain my whole house electric supply but combined with a 2200w propane inverter generator it is plenty to supply power for basic needs.
Robot-Wrangler
Kentucky
I saw the big drop in $. I want solar but it's hard to justify in Texas. My ELECTRIC COOP fixed rate is about $0.11/kw PLUS service availability (aka meter) fee of 26.69/month. in my case it would pencil out better to purchase a couple power walls go with time of use power billing charging at night cheaper and discharging during super peak billing times. About the time you think it will work out with 12 year ROI you remember to include finance cost on the investment adds several years. Then you remember buying 100 sh of TSLA at $22.30, selling 90 when it gets to 200% of purchase and keeping the 10 sh forever.
Given my health and age, I would never live long enough to see a payback for a huge solar investment in KY. I have five 200watt solar panels for my RV for convenience when I travel again. I hope to finish the installation after I recover from my second knee replacement next month. I would prefer to do it myself but I might have to use a shop.
With regards to engine oil viscosity, with my long commute, I verified with two cars that require 0W20 synthetic oil. They will get lower efficiency when thicker bulk 5W30 conventional oil is substituted by hack oil change shops.
srfdude44
california
kia optima
That may be true, although 0W-30 would be preferred for a hybrid. But by the same token maybe 0W-8 would even give higher efficiency, you could try that in your experiments.
m5040
CT
Cummins Dodge
engine has a truly stellar reputation for reliability.
In the US the only recommended oil for this engine is 0W-20 (irrespective of climate region!), but that almost certainly has to do with legality as related to EPA/fuel economy standards, and is not necessarily what's best for longevity. Many or actually most modern vehicles in the US require 0W-20 oil, or sometimes even thinner: 0W-16 or 0W-8 in for instance the latest Toyota engine families. :oops:
as it might "plug things up".
Cheers!
As you say, it has a truly stellar reputation for reliability, why reengineer it?
I don't think you have to worry about plugging things up, I would worry about all the engine stopping and restarting throughout the normal operating cycle of a hybrid but now with thicker oil. Will there be even a fraction of a second delay in building oil psi that could add up to a disaster?
srfdude44
california
kia optima
A delay? If, perhaps, you are in minnesota in December. The viscosity of a 30W oil at 40 degrees F is not to worry about.
m5040
CT
Cummins Dodge
You may not quite get what I was saying, more like how many milliseconds to build acceptable oil pressure for each of the considered oil weights?
Phimosis
Larry
Santa Clarita, CA
I’m in agreement, but outside of in-house engineering results, there’s no proof.
if you design an engine for 0w-10 oil, that means you need to have very narrow oil passages and oiling orifices to maintain adequate oil pressure, according to Poisoulle’s law: the volumetric flow rate is proportional to the pressure difference, the fourth power of the radius, and inversely proportional to the fluid viscosity and tube length.
If you put a high viscosity oil into a system with small tube diameter, designed for a lower viscosity, what is going to happen is that the pressure will go up. But oil pumps have an internal bypass valve to prevent overpressure. And if the majority of your oil is going through the bypass valve, according to Poisoulle's law, the volumetric flow rate is going to dramatically decrease.
Does that cause a delay in the delivery of needed lubrication? Not sure. But it is plausible.
There is a reason that the manufacturer recommends a specific oil viscosity and not a range of viscosities.
Bottom line is 20 weight oil is 20. The 0w, 5w,10w is the winter temp range scale that the 20 (or 30,10,?) maintains the 20 viscosity range (etc).
srfdude44
california
kia optima
[/QUOTE]
srfdude44
california
kia optima
[/QUOTE]
That was the case years ago, before the EPA took over the requirements for manufacturers to specify their oil requirements. Virtually all passenger cars currently (and for the last 10 or so years) all have requirements for 20W oil in the US. But the same cars/engines in other parts of the world have sometimes wildly differing requirements, all the way to XW-40. So no, just because the manual in the US says 0W-20, is that what the manufacturer really wants, just what they are forced to state.
Phimosis
Larry
Santa Clarita, CA
I’m pretty sure you just made all of this up to promote your unfounded beliefs.
Ford doesn’t instruct you to use 0w-20 because the EPA forces them to. That’s crazy talk. Ford instructs you to use 0w-20 because they designed the engine for 20 weight oil.
And they don’t recommend 20 weight oil for every engine. They only recommend 20 weight oil in the engines engineered for 20 weight oil. For example, the ecoboost maverick is designed to use 5w-30. Because of the turbo and higher specific power output, the heat generated is increased and bearing loads are increased, which means you need more oil volume for lubrication and heat transfer, which means you need larger diameter oil passages. Poiseuille’s law says that if you increase the tube diameter, the flow will increase, but your pressure will also drop. The way they can get the pressure back up to the desired range is to increase the oil viscosity.
Same thing with the 5.2 coyote used in the Shelby GT 500 and in the Raptor R. Because it is a high hp engine that will see higher bearing loads, higher average rpm and higher heat loads, they have designed it with even larger oil galleries for higher oil flow rates. Again, larger tubes = lower oil pressure at a given viscosity. So they upped the viscosity again and they recommend 5w50 for the 5.2 L. Factory recommended 50 weight.
If the EPA was forcing them to use 20w, they would have had to design the ecoboost engines and the 5.2 L with smaller oil passages, but then included more oil passages to provide adequate lubrication, heat transfer, adequate oil pressure and still comply with a law that forces them to use 20w oil. But no such law exists. So Ford doesn’t go that route because more oil passages = more expensive to design and manufacture.
And there’s no “wildly differing requirements” for different parts of the world. A 2.0 ecoboost maverick in the US, a 2.0 ecoboost Kuga in Europe or a 2.0 ecoboost Taurus in China all recommend 5w-30, or 0w-30 if above 5,000 ft elevation or below -4F temp.
Nope and more nope. They are not forced to tell you to use 20w oil. And they unequivocally tell you in the user manual that you should not be using anything other than their recommended viscosity.
Ford Maverick 2.5L Hybrid - Change to 5W-30 oil IMG_2201
Master Blaster
Master
Toronto
The cold number is the important one on the Hybrid. The hybrid engine rarely gets up to the temperature of the EcoBoost, and routinely spends its time a lot cooler. No matter any other number, you want 0W synthetic oil and no other. Its all about the first 20msec of lubrication, not weird other numbers like viscosity during a race. Some dealers have been putting in the 5W30 that they use on the EcoBoost, and that will kill mileage and engine life. There are some disadvantages in using 0W30 instead of 0W20, like an increased amount of plastic in the oil instead of something that actually lubricates, but given that the engine rarely reaches EcoBoost temperatures, maybe you can get away with the hot number being weird.
Robot-Wrangler
Kentucky
I heard that Aunt Jemima pancake syrup is a sweet substitute for 0W20 oil. I would like confirmation from the lubrication experts trolling this post before I fill up my $40,000 2025 hybrid lariat awd crankcase with syrup. 😆 I'm diabetic, so perhaps I should use sugar free? What do y'all think? [🐂💩 bs alert]
srfdude44
california
kia optima
Well thats a lot of words, most of which is simple conjecture and guesswork on your part.
"I’m pretty sure you just made all of this up to promote your unfounded beliefs."
LOL, my beliefs are much more than unfounded, while yours....
Re: the Raptor and Coyote, there are exemptions for high performance engine/cars.
Here's a little secret, Ford (and all other manufacturers) are responsible for the length of the warranty. After that, well you are on your own. And the quality of oil, inc. 0W-20 is good, and with frequent oil changes will work just fine. Do you recall just a few years ago when manufacturers were saying transmission were sealed, no service required? Do you think a transmission would really last over say 100K miles with no service? Ask any tranny shop about that.
While there is no "law" regarding oil, the EPA is god. Period. They require the total fleet of cars a manufacturer makes to hit certain fuel economy numbers. So maybe a 'Vette or Cobra etc may get by, the total sales of those cars is very small compared to the total numbers, and thus won't affect the fuel economy numbers. And while the mileage difference between 0-W20 and 30 is small, over a million cars total it will make a difference.
Obviously you have never heard of CAFE. Corporate Average Fuel Economy. Before you start telling folks that they are crazy and have unfounded beliefs, you might educate yourself.
