- First Name
- Mike
- May 3, 2024
- KC Metro area
- 2005 Toyota RAV4, 2024 XLT Hybrid
- Engine
- 2.5L Hybrid
The Battery Saver mode starts at 12.1 V, when lights start going off sooner, power port plug shuts off sooner than max, passenger keyless entry sensor left off, ect.According to Ford, the Battery Saver Mode on all Ford vehicles is activated in 3 situations:
--Battery voltage less than 9.5 volts
--Inactivity for 14 days or more
--Extremely hot or cold weather.
...So after many BSM activations and a battery replacement (with an AGM battery) on my 2024 Maverick hybrid in October, I have been obsessively monitoring the new battery. I got a trickle charger and installed the Ancell BM200 monitor for my iphone. So far it has avoided the dreaded BSM. I have noticed some weird activity on the SOC (state of charge) levels, such as...
--Leaving the door unlocked can cause the SOC to drop (but not always)
--Leaving the tailgate open can cause a drop
--Even when locked, if the key is nearby it can cause a drop in SOC.
I am still trying to figure out how this all works. The Ancell records 5 days of activity. For some reason last Friday the SOC plunged to 34%, so I had to go for a 30 minute drive to bring it back. Since then (and a 250 mile trip) it's been between 70 and 90%. But no BSM!
Consumer Reports had a pretty good article recently on making the battery last for all cars. It covers many of the things I have noticed. Here's a link:
https://www.consumerreports.org/car...ake-your-car-battery-last-longer-a7617960844/
What you quoted from Ford is on their page for Deep Sleep Mode - you can add a 3rd to that list which requires a scanner to read the PID - Ford SOC scale below 40%.
That same info with 3rd criteria is in an SSM. Funny enough - about false DSM alerts.
Be aware the SOC% on the Ancell doesn't match Ford's SOC scale, which has an 85% max when fully charged.
So that 34% on normal charts for AGM SOC, was probably around 11.8 V I'd bet.
And 70-90% on that SOC scale, is 12.3-12.7 V - so indeed no battery saver mode.
Appears to be holding strong!
Mine has been living at 11.8 V for months now, and no 30 min drive was ever going to get my FLA battery recovered - so that's great for yours.
Actually - had a nice cold 15 F morning today - since battery was so cold (even the HVB only got up to 35 F, it wasn't given much charge either), the system barely spent any time charging it, started and ended at 55% Ford SOC scale.
I'm expecting a few of these cold days will finish it off since barely any charge thrown at it.
Fob nearby for keyless entry, should stop sending out a signal if it stops moving, therefore truck should be in normal receiver mode as if the key was anywhere.
If you really see a difference - your fob may not be working correctly.
Test it - leave it on a shelf by the truck door after locking.
Come back 30 min later - trying to open with keyless touch not moving fob.
Tailgate open, hood open - both are states the system watches, like cabin light left on.
If the battery isn't too low - monitoring system will be left on for 75 min max seeing that, and hopefully not get stuck in some loop or have an issue turning it off later. If locked it's much shorter than 75 min.
