- Oct 31, 2021
- New Jersey
- Chevrolet
- Engine
- 2.5L Hybrid
No retooling necessary for model year change over. It's the same body, same engines and same interior. Only option availability has changed. If anything they might shut down for a day or two to do some maintenance that was maybe put off. Once there is a firm scheduling date it usually takes one to two months to start production. Some cases it was three weeks but that is not the norm. Theoretically they could build '22 models the same time as a '23 since the assembly line is only putting the truck together based on the order. Everything is sequenced for build.They are having to retool their lines and thinking to accommodate the huge number of hybrids ordered, so they can actually produce that many, thus the delay. My guess is as good as anyone's, and that's the hope I wish to hold onto.![]()
Well true except for Tremor which is a different body code.No retooling necessary for model year change over. It's the same body, same engines and same interior. Only option availability has changed. If anything they might shut down for a day or two to do some maintenance that was maybe put off. Once there is a firm scheduling date it usually takes one to two months to start production. Some cases it was three weeks but that is not the norm. Theoretically they could build '22 models the same time as a '23 since the assembly line is only putting the truck together based on the order. Everything is sequenced for build.
1971 Maverick base price $1995 new. We had one and as usual no one could afford the payments back then on $1.60/ hour minimum wage At 8.5% interest rate. Now x10 more the name sake still can not be afforded at minimum wage $7.20/hr. and climbing interest rates. Ford said originally he brought cars to the masses to be affordable, but did he really? Is Ford closer or farther away from this montage than ever before?
Which they could have made the tooling changes for back in July when they had a 2 week shutdown or they could wait until the Christmas shutdown to make any required changes. And not make any Tremors until then.Well true except for Tremor which is a different body code.
tools have a lifespan. they retool everything nearing it lifespan and inspect and re-calibrate the entire line. a modern automotive production line is a fine tuned machine. you cant just ignore maintenance.No retooling necessary for model year change over. It's the same body, same engines and same interior. Only option availability has changed. If anything they might shut down for a day or two to do some maintenance that was maybe put off. Once there is a firm scheduling date it usually takes one to two months to start production. Some cases it was three weeks but that is not the norm. Theoretically they could build '22 models the same time as a '23 since the assembly line is only putting the truck together based on the order. Everything is sequenced for build.
That $1.60 would be around $22 today if we were still using real money. ie Silver Dollars and paper money backed by gold, rather than red ink. Just be glad interest rates are not 8.5%. Yet.1971 Maverick base price $1995 new. We had one and as usual no one could afford the payments back then on $1.60/ hour minimum wage At 8.5% interest rate. Now x10 more the name sake still can not be afforded at minimum wage $7.20/hr. and climbing interest rates. Ford said originally he brought cars to the masses to be affordable, but did he really? Is Ford closer or farther away from this montage than ever before?
Did you have breakfast pizza with it ?So unexpected! I almost dropped my breakfast beer.
