Windshield Alignment Pin - Rattle Silenced…finally.
E30andrew
Andrew
Lafayette, Louisiana
'23 XLT FX4 EB
That's how would have described mine. It was a constant "clicking" with the passenger side being more noticeable. As soon as I had the pins pulled, the windshield has been silent.
Thanks, it has definitely gotten a bit annoying after only a few days hearing it. Did you have it done at the dealership? how long did it take? Would be great to not have to leave it at the dealership for a few days.
mdl20813
Idaho
Cactus Gray Maverick XLT
I had to have my windshield replaced a couple months ago so I took it back to the glass place. They had the pins out and everything put back together in 15-20 min.
stretch119
Jordan
Ohio
2022 XLT Hybrid
Does anyone have any video/audio of what this 'rattle' sounds like? I noticed while driving the last few days there would be an audible 'tick' or 'click' coming from what sounds like the passenger side of my windshield. I wouldnt call it a rattle, but more like a click occasionally. Is that what this is?
Mine sounded like a passenger side “tick” or “click” as well. I followed the instructions in the post that @GTBuzz shared above and removed the passenger side alignment pin. The passenger side noise is completely gone.
Now that the passenger side is so quiet, I’ve noticed that I seem to get an occasional click from the drive side as well. I may repeat the process on the driver side tonight. It only took about 15min, so it’s very easy.
Braderick
Braderick
Brad
High Point, NC
Mav XLT, RAV4 Hybrid, KIA EV6
I felt more comfortable melting the short pin off. I used an automotive panel removal tool to separate the glued base from the windshield. Other assorted tools as needed. Heavy use of silicone pads everywhere…the iron gets super hot.
Ford Maverick Windshield Alignment Pin - Rattle Silenced…finally. IMG_8065
Ford Maverick Windshield Alignment Pin - Rattle Silenced…finally. IMG_8060
Ford Maverick Windshield Alignment Pin - Rattle Silenced…finally. IMG_7964
Ford Maverick Windshield Alignment Pin - Rattle Silenced…finally. IMG_7968
Ford Maverick Windshield Alignment Pin - Rattle Silenced…finally. IMG_7967
Ford Maverick Windshield Alignment Pin - Rattle Silenced…finally. IMG_7969
Added for context…
Ford Maverick Windshield Alignment Pin - Rattle Silenced…finally. IMG_7963
kkreit01
Korey
Olathe, KS
'22 Maverick, '17 Grand Cherokee Limited 4x4 V6
So you melted it first, in order to loosen the glue from the windshield? Then the whole thing popped off?
Braderick
Braderick
Brad
High Point, NC
Melted the pin off between the metal and plastic base. (The metal pin locator is easy to bend downwards if more space needed.) Plastic base was separated from glass using automotive pry tool. Pulled the base out with small hook tool. Veery, very, very carefully.
It’s risky…so any efforts made are an individual’s owndecision.
I’m happy with my results, and thought it a less risky method than a saw blade, nor did I want the windshield pulled/replaced.
Ford Maverick Windshield Alignment Pin - Rattle Silenced…finally. 1682177396081
JME42
Jordan
Tennessee
2023 Ford Maverick
Added for context…
Removed the alignment pins over the weekend exactly as described here and am happy to report the cold weather rattle noise on both sides is now completely gone!
tkammen270
NNJ
2022 Mav, 92 Legacy, 05 WRX
I have had this noise for one year. It drives me crazy in the cold. Finding this thread is a miracle. I plan on removing the pins today. Below is a video of the sound I have been hearing.
Blu
N/A
What about just wrapping it in some foam rubber instead of cutting it?
tkammen270
NNJ
I did not cut the pins. I was only getting the noise from the passenger side. I pried on the metal a little and maybe moved it a eighth of an inch and no more noise. A lot easier than cutting it. If the noise comes back I will address it again. I'm just happy to know what is causing the noise.
clos0791
Carlos
Maverick Lariat, Alto Blue AWD
I was thinking the same thing. Maybe wrapping the pin with foam or rubber tape?
deej
2023 Maverick 2.0 Lariat, AWD, 4K, Lux, BAP, HPR
I've been thinking maybe squirt a little silicon sealant around it to stop it from moving?
jcosh84
Pittsburgh, PA
2023 Ford Maverick XLT Hybrid
thank you! This has been driving me insane since I purchased the truck. I’ve tried so many things to get it to work and nothing has been effective. Today I was about to go ahead and start cutting the pins off when I saw your comment about bending the metal and it absolutely worked and if it comes back like you said, I’ll address it then. Taking a set of needle nose and just bending it back-and-forth pinching the pin or even just providing space is the solution for now.
jcosh84
Pittsburgh, PA
Well that was short lived. It’s back and it’s worse than before. I’m literally going to lose my mind. Every dealership around me doesn’t even want to take my appointment because they said they’ve never heard of my issue and don’t want to sign up for a witch hunt.
** came home after a maddening drive of “ticking” and got out the heat gun- pry tools and multi.
pulled A-pillar, looked up its right there. Hit with some heat. Pried loose, and cut in half. Next update is if it’s fixed.
