Will Upsizing from Stock Tires Void the Warranty?
Montana
245/65R17 would be the safest biggest option. And sure, if they can somehow magically prove a component went out prematurely due to increased angles after adding bigger tires - it can void the warranty - but I don't know very many mechanics who are going to make a fuss over something like 245/65R17's compared to the stock 225/235/65R's these trucks come with. Once you start getting up there in the 70R's, then you are pushing it. Not hard to blame a premature detonation on suspension or half shaft issues when you go 2" taller than stock. For example - people running 255/70R17's... that's roughly 2" taller alone and then they add 2" spacer lifts. That's called a warranty voider. Keep in mind, this is a lower unibody design, not a body on frame truck. Your driveline suffers more in the long run than your suspension angles do in the short run.
That said... you do you. Also, to those reading who will get offended by this post - I don't care. I still love you even if you are a disaster :poop:
Flub
Flub
Alberta
Ford Ranger 08
Do you think a 70 on its own would kill it?
Hardening2753
Ford Maverick Hybrid
ShadowChas
Chuck
2022 Ford Maverick XLT FX4
Because thems really small tires
Actually Ford would have to prove that your changes caused the failure (whatever it was?) but the only thing I would suggest is checking out the tire website’s showing proper + sizes so the odometer is within range, but again is upto you 😉
Ron Neal
Ron
SC
Sold Ranger
I think if the dealer said something voids the warranty it's more like you have to prove that he can't prove it. :)
pa-outdoorsman
PA
2022 Maverick XLT, EB, LUX, FX4, 4K, Cactus Gray
I'm not offended by your point of view. But I might be a little hurt if you feel I'm a disaster! 😢
Love my Eibach lift springs and 245/70s.
Ford Maverick Will Upsizing from Stock Tires Void the Warranty? IMG_9610
Admittedly, we have no long-term history with the Maverick, as there are none more than 2 years old at this point. Only time will tell how much impact these mods have on suspension components.
I don't know the future but my guess is that like any other vehicle, some will have issues and others won't. The way the trucks are driven and maintained will play a big role.
mav_kev
PA
Mav
What? No!
commadorebob
Tires and rims are considered consumables. So, I would think not. Now, if you start hacking on the drivetrain....
Dudley
Doug
Indiana
2003 Grand Cherokee
I get very uneasy around trucks with very deep and wide wheels replacing the stock ones. Saw one on the side of the interstate with the whole right front tire/wheel/rotor/caliper and part of the suspension laying on the ground. The stress that puts on everything apparently did it in.
