Why new intake/manifold design for 2025 Maverick?
envymy300
Cody
Fredericksburg, VA
2025 Ford Maverick
Does anyone know why ford redesigned the whole intake/manifold for the 2025?
I’m still excited about my truck, just bummed a bit that I can’t go ahead and order the S&B Intake to have ready and waiting to put on when I receive my truck from the dealer.
after seeing pictures of the actual layout of engine, it’s not making a ton of sense for all the changes
EVH5150
Southern Vermont
I would say that there's a pretty good chance that it has changed. Ford added port injection to the direct injection for 2025
envymy300
Cody
Fredericksburg, VA
2025 Ford Maverick
Oh I know it’s been changed I’m just wondering why. Just because you add a certain injection doesn’t mean you have to change the intake. Seems like a lot changed just because of some tiny details.
Specially if the aren’t adding the GPF until job 3. Saw that in a different thread that those wouldn’t be installed until those start production
Well, when those injectors need to be mounted in the intake...
OleKennyRoy
Kenny
Maverick Lariat
Dual injection to eliminate the valve coking... Gotcha. I'd hoped the new oil formulation/additives and a relocated PCV would have made this unnecessary.
Dueces
It's a whole new engine design. Even the 2.3L on the other models have a similar change with the intake filter attached to the front of the timing cover on the rwd platforms. I assume it's for packaging reasons, however, seeing the 2023 ford escape with the same engine, where the airbox used to be is now just a huge void above the trans....
CajunMick
Heman
Houston, Texas
2023 XLT Maverick
Humm, meanwhile us owners with 2022-2024 models stuck with potential “coking intake valves”?
Anyone with the new 2025 EB engine? If so, maybe couple pictures of this intake manifold setup.
OleKennyRoy
Kenny
Maverick Lariat
It’s common with all direct injection engines. Oil vapor collects and solidifies on the intake valves. Normally the fuel washes it off in port injected engines.
On other 2 liter Ecoboost the PCV vapors effected cylinder 2&3 more than 1&4.
BMW has a process that uses walnut shell blasting to clean.
Packer Bill
South Dakota
Do you have any source material from Ford to confirm this? I asked Tim, the @fordvideoguy, if he could confirm with Ford whether the 25 EBs had both port and direct injection. Tim said that he could not get an answer from Ford...
envymy300
Cody
Fredericksburg, VA
2025 Ford Maverick
Here ya go!! Sorry for it being kind of dark. Sun isn’t up yet in Idaho.
Would you be willing to take some more pics and upload them from different angles when it’s lighter out? Would love to see more.
Also, I was reading the the EB wouldn’t have the GPF until Job 3. Are you able to confirm that your EB does not have the GPF?
envymy300
Cody
Fredericksburg, VA
2025 Ford Maverick
Thanks for the info
dalola
Retired
SE Ohio 🇺🇸
Well, one thing is for sure, the ATF R&R will be a lot easier on a '25! 🤠
