Which hood bug shield is best for the Maverick?
Jdodson
Denison texas
2024 ford maverick
Which one have maverick owners been the happiest with?
Master Blaster
Master
Toronto
23 Maverick Lariat Hybrid
I'm holding off getting one, since they all seem to stick on to the paint with double-sided tape. I don't see any way to remove them to clean underneath. Long term its a really stupid design. Why doesn't someone make one that screws on under the lip, like my Rangers used to have?
Jah.
Jah.
Central Florida
bugflector mounts under Hood and leaves about one inch from Hood to clean with sponge or rag . also protects front edges of fenders . originally had to Dremel out 2 center holes to line up to fit . mine is over 2 years old and so far so good . hopefully avs has straighten out the alignment issues by now .
Ford Maverick Which hood bug shield is best for the Maverick? 20220509_141016
SLJ
Elbridge New York
They do: EGR Superguard Bug Shield. East install.
Ford Maverick Which hood bug shield is best for the Maverick? bug shield EGR
Master Blaster
Master
Toronto
A quick read of the EGR installation instructions shows that you wrap 3M tape over the front edge of your hood on to the outside paint. The main attachment points are screws underneath the edge, but then there are 6 bumpstops that have to be glued onto the top of the hood. That's a lot of glue-on stuff to ruin the paint when removed.
They would not need the wrap-over tape if they moved the plastic even 1/8" away from the hood. Sticking the bumpstops onto the hood instead of the underside of the plastic is also odd, adding to the paint destroying problem.
Tbone289
I've never experienced adhesives from double-sided tape or decals ruining paint when removed correctly with a heat gun. Have you?
VinylImagination
Simon
vinylimagination.com
F-250, Fusion, Navigator
Can't speak to double sided tape.
However, we have never come across an instance where the paint has been damaged by the adhesives from decals, graphics, or wraps.
Not when removed correctly.
Realtruck
Diamond Sponsor
Realtruck
Ocala FL
It comes down to your style preference. If you're looking for something that sits slightly off the hood, then the AVS® Bugflector® II Bug Shield is one option, or if you prefer matte then the EGR Matte Black Superguard Bug Shield is a popular pick. If you like a more streamlined, sleek appearance then definitely the AVS® Aeroskin® Bug Shield. It's an aerodynamic design with a low-profile that perfectly hugs the contours of the hood. These are 3 that are often requested for the Maverick.
SLJ
Elbridge New York
I didn't use the tape and it doesn't touch the front or top of my hood. In fact there's enough space to put my canoe hood loops under it to tie my canoe bow lines to.
If the bump stops are glued to the shield, the tips would constantly rub on the paint instead of rubbing on the bottom of the shield and you don't want that.
Waterick
Laurens county SC
I believe the stand up style does provide more protection for the windshield. Both from bugs and stones, my 2001 Ranger has a Bugflector II and still has its original W/S at 130k.
James K
NY
2022 Maverick,1960 Bugeye, 1973 GT6, 2016 R1200GS, 2024 KLX300
Nope, I actually use a hair dryer as it doesn't need a lot of heat. I've done hundreds of stickers and trim pieces and never ruined the paint.
North Coast Joe
NW Ohio
2024 Ford Maverick XLT Hybrid. 2022 Honda CR-V EX-L
I purchased the Lund textured deflector with my Ford Pass points. It fits and looks nice. Yes it uses the 3M tape system. Since I will not be driving in Ohio winter weather I am not worried about corrosion.
asylus
George
TEXAS
'24 Ford Maverick Lariat Tremor
I just pulled the trigger on the textured one thru Ford since their shipping is the cheapest and currently have a promo for 20% off.
Ford Maverick Which hood bug shield is best for the Maverick? IMG_1478
