Where do you put your garage door opener?
SiestaG
Gerard
Siesta Key FL
2024 Maverick Lariat
I bought a cubby drawer (etsy) and hang the opener from it. It's recessed just the right amount and gives something i can push against to push the buttons. Thankfully, my opener is kind of small.
Ford Maverick Where do you put your garage door opener? 20231219_094730
Old Ford Guy
Rod
Northeast Ohio
2024 Maverick Hybrid Lariat ; 2016 Linc Navigator
very nice, looks like it came from the factory like that.
Zjr
VA
Non Fords
Not a garage door, but the entry gate is only in my Maverick when I have my phone... but it is always with me in any vehicle.
I use eWeLink.
Ford Maverick Where do you put your garage door opener? 1000029457
Gray Goose
RG
Wissota
Maverick XL 2024, Escape 2012, GMC Terrain 2017
I bought this style of Liftmaster remote and put it in the cubby.
I've had that remote for years. First thing put in the truck when I brought it home early this week. Perfect fit, it's like the dash cubby was designed for it.
Ford Maverick Where do you put your garage door opener? PXL_20240416_000549817cro
HotRod
Delaware
2011 Fiesta
The one I installed is a Gentex 536. However a Gentex 453 is a popular one that I see installed in Mavericks. There are probably many other Gentex models that will work. However pay close attention to the mount. Make sure that the mount is the same as the Mavericks. Also make sure that the wiring harness is included with plenty of wire. Hope this helps...
Nunya, I see the 536 has the connecter on top of the windshield mount. Does that interfere with the black plastic cover on the top of the windshield? Do you have any pictures of it installed?
arseatea
Reggie
Beavercreek Ohio
2022 Ford Maverick, 2011 Lexus ES350, 2004 Ford ST
I had been keeping my garage door opener where it seems most of you keep yours, the little square hole near the cup holder. But, at night, it was hard to find and with no light at that time, it was hard to use. So, I moved mine up to the 2.5"X4" hole to the right of the GPS screen. I used one of my wife's unused pot holders, and just clipped the opener on it and stuffed it into the hole. It is a perfect location, out of the way, and easy to find and reach. The problem is, it's temporary. I need something more permanent. Something that fits the decor a little better. Maybe a 3d printer can print a soft plastic hinged device that not only will fit, but looks good. Maybe utilize the space behind the opener for a coin holder or plackers or something small. I'll be the first customer for a permanent solution. I would like to send a pic of what mine looks like, but I am not good at posting a pic except on certain chat groups.
I took someone on this site's advice and bought a little box from Etsy ($25) that was made for the cubby hole, and mounted my opener on it. I consider it a temporary fix, but it works fine, The box is unusable for anything else with the opener on it. I know that down the road Ford will come out with something for that cubby hole. Then I will have to find a more permanent solution. I like to keep my cars and trucks as factory as possible, so I am reluctant to change the rear-view mirror.
lajlmt
Lance
Rio Rancho
‘23 Maverick XLT LUX
Um how did you get your infotainment screen so bright??
arseatea
Reggie
Beavercreek Ohio
I don't think I did anything - that is the way it has always been.
That is probably the same one I have too. A little difficult to remove with the opener there, but not impossible. Might be a good place to store some seldom used smaller things.
Gullzway
OK
1968 Ford Mustang Fastback
How do you convert an opener to a smart opener? Mine is about 10-15 years old and probably incapable of learning any thing new. Thanks for the comment.
A little late, but this will convert almost any garage door opener to a smart opener.
I've had mine for about 5 years on two different garage doors.
No need to press a button I just say hey Google open garage door. Works with Siri as well.
I don't even keep my garage door opener in my truck.
Looks like they're $35 right now.
Limited-time deal: meross Smart Garage Door Opener Remote, Compatible with Apple HomeKit, Amazon Alexa, Google Assistant and SmartThings, No Hub Needed https://a.co/d/cXkirNf
5GallonCan
Larry
2024 Maverick Lariat Hybrid
I installed a Gentex mirror from Bob's Mirrors. They usually have specials that are discounted and will work in your Maverick. I emailed them about the particular special that was $39 and they confirmed it would work in my Maverick. I ordered the long cable to connect under the dash. They give you instructions. I tapped into the connection for my dash cam. Bob's provides the quick-connectors, so it was easy and took only a couple of hours total, including programming the Homelink. You have to pop off that housing behind the mirror. I used the plastic trim tool that came with my dash cam to pry along the edges and pop it off after confirming that works by watching a Youtube. I only have one garage door to open, so I programmed all three buttons to the same opener as it is difficult to see the actual buttons on my mirror in dim lighting.
Ford Maverick Where do you put your garage door opener? Gentex Homelink Mirror2
I mounted / concealed my mini remote within Reach on my driver's door.
Ford Maverick Where do you put your garage door opener? 20241217_075318
