Wheel spacers for rear
2025 Maverick XLT
I know not another one but ive looked everywhere and cant find a answer for my setup. I look all over on here but cant find any answers for stock wheels. I even asked AI and kept getting conflicting info. Im looking to extend my rear wheels flush or slightly past the wheel well, what size can i get without modifying studs or anything else. My truck is a XLT AWD with stock wheels. I also plan on lowering the rear an inch down the road by installing the rear lobo springs if that matters.
Mudduck
JD
Utah
https://www.steeda.com/hr-5035633-focus-wheel-spacer-25mm
Are you running factory wheels? a few youtube guys have ran 2" spacers without much recourse.
2025 Maverick XLT
Wouldn't i have to modify the studs to make these fit
Chops
Lobo
The little (nothing) I know about hub spacers is “be careful”. Maybe start with the thinnest and see how they handle before going thicker on your situation? Add your experience to the MTC knowledge base:)
Are you going to install the Lobo springs yourself? Suspension is another area I don’t trust myself to fiddle with. But the Lobo handles better than any vehicle I’ve driven.
Mox4615
Jeremy
NC
2024 Lariat
I bought some hub centric spacers from Bonoss and they have worked well for me.
25mm front
35mm rear
No modifications to the studs just bolt on and go
2025 Maverick XLT
I was planning on it but haven't really decided yet
2025 Maverick XLT
25mm front
35mm rear
See thats the confusing info i was getting from AI. AI says 35mm wont fit without getting longer studs.
Chops
Lobo
25mm front
35mm rear
What wheel and tire size? Does that make a difference in spacer choice?
Mudduck
JD
Utah
Mudduck
JD
Utah
Ok well i guess ill give it a try and hope for the best.
Take some measurements to there you want your wheel to sit. Convert that to mm, and order something close as you can get. Spend the money to get quality spacers.
2025 Maverick XLT
Yea i did. I think 35mm may be slightly past the wheel well.
Johnkn
MD
Bora spacers. None better. https://www.motorsport-tech.com/bor...M0UDC7RDNrh7ACjBHNHRdmlqiAEUWIEcaXtfSbqxBsFfa
Always use the highest quality hub centric spacers.
Careful with 25mm (1“) spacers on the rear. They ..may.. be too short and allow the stock wheel studs to contact the back of the wheels and prevent the wheel from fully seating, though the factory wheels do have pockets on the back of their hubs that accommodate some of the stud poke.
You need to remove the wheel in question and measure the stock stud length and do the math.
good luck.
Hot Runr Guy
West Chicago, IL
good luck.
Here are the pockets discussed above. Measure the length of the studs, and if longer than the thickness of the spacer, the extra length would go into these pockets, if deep enough.
Also, when looking at spacers that use a 2nd set of studs, make sure they use the same size stud, which is 14mm x 1.5mm pitch.
HRG
Ford Maverick Wheel spacers for rear s-l1600.12
Master Blaster
Master
Toronto
23 Maverick Lariat Hybrid
1" or 25mm spacers come with their own grade 10 lugs in secondary mounting holes, and the existing lugs do not need to be cut to fit. Just bolt them on. I had to add them on the rear with my 2" flares or it looked weird, but didn't need them on the front. Be aware that in some jurisdictions it is illegal to have the tires out past the fenders, so you will need flares. Besides, tires out that far look stupid.
