What LED rear lights are we using now?
Jetlat7878
Woodstock, GA
Maverick Lariat BOP Hybrid
Early Lasfit adopter here for my ‘22.
Obviously that didn’t turn out so hot - went through two regular sets and the replacements and then back to stock.
Checking now to see if there’s a better option now. Diode dynamics? Lasfit updates? Anything else?
Looking for rear tails/turns/reverse/3BL.
Don’t need front.
Hello, my Maverick is a 2024 Lariat with BOP. Like you I tried Lasfit LEDs which worked for while but began hyper flashing on turn signals. I decided to use LEDs that I got from Headlight Revolution. I also installed in-line resistors for the front and rear bulbs. Worked great for about a year then the right side started to hyper flash. I took the truck in for some other minor issues to my local Ford dealer and had them check for hyper flashing. They said I had a bad resistor on the right side. I did a R&R for the resistor on right side tail/turn signal wiring and now everything works as it should, no problems at all. You might try Diode Dynamics, I would do the first. I would not skimp on price, quality is the key for the happy results in my mind. Cheap LEDs don’t last long. Best of luck!
JustDoIt
CK
Dallas Tx
'20 JLU Rubicon, '17 JKU Sport
The Auxito is for front turn only, I tried the red Auxito in the tail lights, drew too much power and shut the BCM down. That’s why the DDM TUNING works great
I used DDMTuning for HIDs on my bimmers for a LONG time - they make tail bulbs you like?
Tech Tye
Ken
Kentucky
2023 Maverick
Yep, the brake lamp bulbs are great, very bright and so far long lasting. They are using CREE LEDs
Tim d
Alpena
Ram
Don’t need front.
Stock.
Frenchy
Bert
Taylorsville Utah
20205 Maverik Hybrid AWD 4K town, read
Don’t need front.
I ordered these one from Walmart as I could not get them from Amazon:
https://www.walmart.com/ip/Alla-Lig...ite/1288040465?classType=VARIANT&from=/search
In addition, they a bit cheaper at Walmart. I should have them tomorrow
A lot depends on the resister. A low quality one's resistance can drift as it heats up. Early 23 some were posting that if they had lights on for 20-30 seconds the bcm would shut down the circuit. After a period of cooling time the next time truck was started the bulbs would work.
Frenchy
Bert
Taylorsville Utah
I installed Led on several of my vehicles in the past and I had not issue.
I had issues when I bought LED for the backup lights on my 2025 Maverick as contrary to what the website site said (Amazon) they did not fit in my socket. I had to modify them and they have been working since but I still replaced them for one who fit the sockets. I am waiting for the ones from Walmart to install them and then try the whole thing.
Pointyears
Richard
South Central PA
2025 Maverick Lariat, 2018 Mustang convertible, 2012 Harley Softail, 2024 Vita
Joaquin F
Joaquin
LA
2022 Mav Hybrid XL
Don’t need front.
F150 LEDs have some bulbs which I might try out soon.
Naranjita
NAH-RON-EE-TAH
Steamboat Island, Washington
I used the ALLA bulbs on my '22 Maverick. They worked great. Never even caused a hyperflash for 1.5 years, until I had a recall where they reflashed and the BCM reset, and then started hyperflashing. I had to use Forscan to remove the hyperflash after thar. Loved the bulbs. I had blacked out my rear lenses, and these were very bright through them. Even brighter than the OEM before blacking out.
They were still in that Maverick when I sold it in December '25 and bought my new Mav.
JMJB
Fresno California
'22 VB XLT Hybrid with Sunroof
