What LED rear lights are we using now?
Naranjita
NAH-RON-EE-TAH
Steamboat Island, Washington
Naranjita. I never used forscan. if I had to do it , how to do it?
https://www.mavericktruckclub.com/forum/threads/confirmed-forscan-hyperflash-fix-post-recall.42179/
https://www.mavericktruckclub.com/forum/threads/forscan-101-step-by-step-how-to-start-guide.7406/
There is a lot of info on this site and other places. I don't know what I'm doing. But I keep reading and watching until I have enough confidence with each thing. I should be the last one giving step by step guidance. But I'm halfway intelligent and follow along everyone else and have not had any issues with Forscan, yet. I have not attempted to use it on my 2025, yet.
Frenchy
Bert
Taylorsville Utah
20205 Maverik Hybrid AWD 4K town, read
Thank you so much.
mepot101
Orlando, Fl
2024 Ford Maverick
I have the Diode Dynamics rear tail/turn signal bulbs. Added the resistors from them, mounted inside the taillight area. The have worked perfect.
I did use heat shrink and butt-splices though, I do not use those scotch-lock style wire connectors.
JustDoIt
CK
Dallas Tx
'20 JLU Rubicon, '17 JKU Sport
Yep, the brake lamp bulbs are great, very bright and so far long lasting. They are using CREE LEDs
Do you remember specifically which ones?
Do I remember right you need two pair of both or is only one of the pairs used for signal
mepot101
Orlando, Fl
2024 Ford Maverick
I used the model DD0051, HP11 bulbs.
It takes 4 bulbs and 4 resistors.
I've had them in close to a year, so far so good.
Frenchy
Bert
Taylorsville Utah
I just replaced all three light bulbs on each side on my 2025 hybrid XLT with LED and so far everything is working perfectly, no hyper flashing and extremely bright
Itsdavebr0
NY
2024 Maverick XL
I’ve been running these for over 2 years without issue.
(used FORScan to disable hyper flash)
kev-o-lobo
Kevin
DFW
2026 Ford Maverick Lobo
What resistors did you use?
The resistor would need to have the same resistance of the bulb replaced less the resistance of the replacing LED plus having the feature of the resistance being stable and not drifting as the resistor heated up during use.
kev-o-lobo
Kevin
DFW
Oof...math...
