Lariat rear backup lights - are they LED?
MJL
TN
Ram Rebel, Maverick Lariat hybrid
Does the Lariat have LED bulbs for backup lamps. Will be removing taillights to install swing toolboxes and would be easy upgrade. Didn't know if rear lamps are LED from factory
cyberdog
Ray
2023 Maverick Lariat Hybrid
They appear to be incandescent bulbs for running, brake, and backup on the Lariat. Only the signature trim/accent lighting is LED. I'll probably upgrade mine to super bright LEDs in the next couple of months. - Just took delivery three weeks ago, and a bed cover and bug/stone shield are my top priorities at this point. Planning a weekend road trip next month for our anniversary, and want the her protected, and a secure place for our luggage & anything we buy.
MJL
TN
Just a suggestion on bed cover not many of them are not 100% dry, I have a low profile pallet I built to elevate soft suitcases from bed floor. I have a gator and it does pretty good but still sometimes a little water in floor
raymaines
Ray
Tacoma, Washington
Alto Blue Lariat Lux Hybrid
ALL of the Larieat rear-facing lights are incandescent. I've replaced them with LEDS and think it's worth the cost, but the stock bulbs are all incandescent.
Bobbydontchaknow
West chester, Pa
2023 Ford Maverick Lariat
where did you get the lights? What kind are they? Thanks!
Silver23
Do you have to put load resistors on any of them?
UberGadgetFreak
Mt. Holly, NC
03 Marauder, 21 Bronco, 22 Maverick
I did the LasFit bulbs all around in mine (reverse, stop, third brake, cargo, front turn, side markers). Those have resistors built in so no hyperflash/warning issues.
And well worth the price.
RDRahn
Cleveland OH
Lasfits are great. Did all of mine Too. The reverse lights and running/break bulbs are VERY easy to change, just two screws to remove on each taillight assembly.
jsus
2022 Ford Escape Hybrid AWD
See your manual.
https://www.fordservicecontent.com/...ingEnabled=False&userMarket=USA&buildtype=web
EXTERIOR BULB SPECIFICATION CHART
Replacement bulbs are specified in the chart below. Headlamp bulbs must be marked with an authorized D.O.T. marking for North America to make sure they have the proper lamp performance, light brightness, light pattern and safe visibility. The correct bulbs will not damage the lamp assembly or void the lamp assembly warranty and will provide quality bulb illumination time.
Lamp​
Specification​
Power (Watt)​
Headlamp low beam.​
LED LED
Headlamp high beam.​
LED LED
Front side marker lamp.​
W5W​
5​
Front turn signal lamp.​
4257NA Amber​
26.5/8.5​
Rear lamp, brake lamp, rear turn signal lamp and rear side marker lamp. Low series.​
WT21-7W 26.5/8.5
Rear lamp, brake lamp, and turn signal lamp. High series.​
WT21-7W 26.5/8.5
Rear side marker lamp. High series.​
LED LED
Reversing lamp.​
WT21W​
26.5​
License plate lamp.​
LED​
LED​
Rear cargo box lamp.​
LED​
LED​
Central high mounted cargo lamp.​
912​
12.8​
Underhood lamp.​
LED​
LED​
Note: LED lamps are not serviceable.See an authorized dealer if they fail.
Ottocycle
Baja Georgia
23' RS6 Avant, 14' CTS-V Wagon, 87' BMW 535is
Did the Lasfits all around also. Well worth it. Took maybe 30 min to install them all.
dalola
Retired
SE Ohio 🇺🇸
2nd (3rd?) the Lasfit LED's. The reverse bulbs are the same as the clear bulbs in the CHMSL, so I replaced all 4 of mine......HUGE improvement in bed illumination & reversing at night. The std. bulbs were pretty much worthless for any kind of reverse visibility in dark rural areas. It's a worthwhile change if you are backing up frequently at night, and/or need better bed illumination.
