2016BoostedGreyGoose
Lawrence
16 F150 CC XLT, 21 F150 RCSB, 22 Maverick Lariat
The only thing keeping the PAC APH-FD02 from being plug and play is the external rib on the connectors not matching. You can just trim the harness itself and not need to make any modification to the vehicle side for reversibility. The electrical connections all match up aside from, obviously, the tweeters occupying what's labelled as the rear channel.
Thanks, I wouldn't be modifying the vehicle's electrical side. I built a harness that is specific to the Maverick that requires no trimming of anything because I used the correct Molex connectors in my harness build. Don't mind me. Just thinking out loud...
Chris_G
NOVA
C-6 Corvette
Don't want to give them an excuse to deny a warranty claim.
Hdang1980
Elk Grove, CA
2022 Ford Maverick Hybrid
Anybody know which and where I can find the correct speaker harness for the woofer on the B&O system?
Ford Maverick Upgrading the Maverick B&O Sound System - DIY Howto 20220801_214435
I believe they're Motorcraft WPT-1456 and WPT-1016 pigtails depending on which side you need.
Droid82
Georgia
2018 F150
Hdang1980
Elk Grove, CA
I'll be needing the WPT-1456! Thanks a lot for the help. Now I need to decide whether I want to spend 30 bucks on it or just cut/splice the one from the OEM woofer.
Hdang1980
Elk Grove, CA
So i swapped out the b&o sub with cdt audio 6x9 woofer, but now I'm getting popping sounds at high volumes. I have to lower the bass level to minimal to get it to stop, thus losing most of the bass sound. Any thoughts of what the issue is? I'm running the factory b&o amp.
There's a 4 and 2 ohm version of that speaker. If you bought the 2 ohm version I would expect the amp to not be happy about that, and it will clip.
If you have the 4 ohm version and you're sure it's not reversed polarity then it could be defective.
2 ohm fits the symptoms though so that's probably your issue.
Hdang1980
Elk Grove, CA
I ordered 4ohms but I'll have to check the box again when I get home tonight. Thanks for the tips.
Blazin28
philadelphia
22 Maverick
Anyone have the B&O wiring diagrams for the amp or whole system layout?
Hdang1980
Elk Grove, CA
Hdang1980
Elk Grove, CA
Blazin28
philadelphia
22 Maverick
