- First Name
- John
- Jan 21, 2022
- Bremerton, WA
- 2016 Civic
- Engine
- 2.5L Hybrid
I'm doing everything I can to justify not digging into the dash at all. Really dislike the sound from the dash, but I suspect that might be the center channel if you say the tweeters are fine.The front tweeters are wired directly to the head unit which has crossovers built into it, so I left out the crossovers that came with the Infinity component speakers. Adding wiring from the door to the dash is more work than I am willing to do and it is questionable whether it would benefit the system. Both the tweeters in the factory system and the Infinity's image very well any difference would be personal preference. They work well with the factory crossover.
The Infinity door speakers definitely have more bass response than the factory ones. I measured the frequency response flat down to 40 hz and the factory amp can push the speaker to the point where the entire door is vibrating without distortion. It all sounds very good.
I was considering installing coaxial speakers in the doors but it sounds like you're saying they don't get a full range signal. Do you know what frequencies the doors cross at?
