Unexpected - Can't use my Harbor Freight ramps?
flyswatter
Macon GA
2024 Ford Maverick Lariat, 2020 Lincoln MKZ
I need a ramp to access and leave my back yard, and was previously using some standard Harbor Freight metal ramps. As you can see by the photo below, my 2024 Lariat bumper facia is too low for me to use them now, making contact with the surface of the ramp when the tire is still a couple of inches away. Anyone successfully using another brand of ramps with their Truck?
Ford Maverick Unexpected - Can't use my Harbor Freight ramps? Mav_Ramp_Contact
The forward mud flap looks like it will make contact too, but I'm less worried about that as I can remove it if I have to.
The Real Maverick
Jack
Use wood : 2x8. 2x10 something like that. Just stack layers flat like mini 1.5" stairs.
FYI ramps like that for oil changes:
Put the ramps on the other side of the wheel and BACK up onto the ramps. Works fine.
LtCasual
Paul
Minnesota, USA
2023 Maverick XLT
Hot Runr Guy
West Chicago, IL
I've been using Rhino Ramps for oil changes and they work well. Although it sounds like you're using the ramps to get in and out of your yard so they might not work for that with the large front lip.
https://www.homedepot.com/p/FloTool-Durable-RhinoRamps-Set-of-2-11909MI/205152558
I see that the Rhino Ramps are listed as 17 degrees, here's a handy calculator to help you determine what angle ramp you need;
https://www.raceramps.com/angle-of-...vSGHZjDB4mS_rgqTqo5kERW0ntjg-oBXuDWJPiA7xyzya
HRG
Carlitos_92
Those are the steepest vehicle ramps ive probably ever seen... lol
That's what I was thinking, though I usually don't judge HF stuff that harshly.
If futzing with wood block "helpers" is too much trouble, almost any other ramp set would probably be fine. I'm still using a $40 set of plastic Walmart ramps I bought 15+ years ago...
tysonbisme
Tyson B
24' XLT EB, CGM, SIB
plastic ramps ftw
MaverickMark
2023 Maverick Lariat
I us
I use the plastic Harbor freight ramps. The ramp is more gradual.
LARIATBLACKFUTURE
Nebraska
22 Ram 1500
I set a small piece of 2x4 in front of the ramp on the ground. Works perfect.
SlowTime2011
Edward
Charlotte, NC
2022 XLT EB LUX
I used an old set of Rhino ramps. Maverick had no issue. With my Miata I had to put 2x6 blocks ahead of it.
flyswatter
flyswatter
Macon GA
flyswatter
flyswatter
Macon GA
flyswatter
flyswatter
Macon GA
Toadhopper1
Palm Bay Florida
2024 Lariet Tremor
I was thinking same thing .
I used to do same thing when doing alignment on lowered vehicles to get on the rack. Stronger than ramps too
inline_five
2023 Hybrid XLT
FYI project farm just recently did a ramp test and 5e results were pretty surprising. IIRC the HF plastic ramps performed well above their design limits.
