Wayne
Ontario
RadioSousSol
Stephane
www.radiosoussol.com
Honda Ridgeline
Enderet
I added these 2 weeks ago and got rid of the hood flutter all together
Amazon.com: Red Hound Auto Set of 2 Hood Bumper Stop Cushion Support Compatible with Ford Ranger 1998-2011 Radiator Black Rubber Pair : Automotive
they fit perfect up near the windshield...only too 30secs to install and 10 mins of adjusting
Mind showing us where you installed them? I think im going to buy some of these to fix my hood flutter. You are the only one that has reported having successfully solved the problem. But I also noticed your Mav (at least in your profile pic) doesnt have the hood deflector. Is that correct?
Wx Man
Hendricus
Gray, Maine USA
2022 Maverick Hybrid Lariat
Gullzway
OK
1968 Ford Mustang Fastback
I just installed the Aeroskin 2 today, and it caused the hood flutter. Bought 4ft. of 1/2" heater hose for $8 at AutoZone. Split it lengthwise and put it over the rear hood seal.
Almost removed all the flutter at highway speed. Still a little but it's in the middle of the hood, more like flexing. Could have been there before and I didn't notice.
Ford Maverick TSB & FIX: Hood Flutter Shake at Highway Speeds IMG_20220412_183349
testa422
Charlotte, NC
Subaru Legacy
Did this today. Can confirm hood shake is GONE…even with the big deflector
tonyinsd
Tony
San Diego
Ford Mustang GT, Ford Maverick XL
I did not notice this at all. Of course, my truck was built after this issue was noted and a correction made for it. I had it at 70-80 mph (it's easy to do with how smooth the truck rides) and I did not see any hood shake or rattle.
Nw_adventure
Salt Lake city
Do we know officially that Ford fixed this issue halfway thru MY22 production ?
James St. Patrick
MARYLAND
2022 FORD MAVERICK Velocity Blue Ecoboost AWD
I noticed the hood flex/shake/spasm with my Silver Maverick, after I added the hood deflector Speeds >60 mph and the hood was dancing. Adjusted and readjusted those hood mounts, but the hood flexing remained.
In my VB Maverick, there is no flexing. I did not add a hood deflector because I suspected that was causing the hood flexing.
MLowe05
GA
No hood flutter in our VB XL EB - hope it's the same in our Lariat Hybrid. We won't be adding deflectors.
wjg
William
Mustang, Maverick
If you like the deflector, as I do, fix the flutter! Had truck up to 85mph - no flutter. Fix has been mentioned in this thread.
Ford Maverick TSB & FIX: Hood Flutter Shake at Highway Speeds IMG_20220411_105716~2
Wx Man
Hendricus
Gray, Maine USA
Did you just lay is as pictured or did you fasten it some how (like with an adhesive)? Thanks.
Wx Man
Hendricus
Gray, Maine USA
Did you just lay is as pictured in the fix above or did you fasten it some how (like with an adhesive)? Thanks
