Transmission coolers- 4k tow vs. Tremor
Maverick2022XL
name
hinterlands
In the Ford tracking website for my just scheduled (YEAH!) Tremor, it says it has an "upgraded drive ratio".
One of the most technical reviews of the Tremor says that it has a 3.81 final drive ratio.
https://www.theautopian.com/i-took-...emors-off-road-hardware-heres-what-i-learned/
The Bronco Sport Badlands with the same dual clutch mechanicals has a 3.81 final drive ratio.
The higher drive ratio might also account for the lesser than expected mpg of the Tremor.
I expect that numbers on the datasheet are merely evidence of Ford's inconsistency/incompetence in communications.
Whether it does or doesn't the final drive ratio is not the reason for the lower MPG rating. If that was the case the 4k tow packages would also be lower and they aren't.
Assuming the data sheet is wrong then the 3.81 final drive ratio would provide better acceleration and torque at low speeds and less heating in the tranny.
fossil
ernie
ohio
https://media.ford.com/content/dam/fordmedia/North America/US/product/2022/bronco-sport/2022-Bronco-Sport-Tech-Specs.pdf
I've always felt the FDR was 3.8 simply because, 1 the Tremors intended use and 2 upgraded tire size, 3 Autopian brief comment. Makes no sense to hobble off road performance with the 3.6 ratio. Should be noted that all 2022 Sports have the 3.8 not just the Badlands.
As for the opinion the Tremor has a smaller radiator, the very same PDF content sheet often treated as the last word claims all 2.0L Mavericks have the same coolant capacity.
PCK
Phil
VW R32; Maverick Tremor
I suppose that the next question is, for those in the northern climes or who want to live dangerously, can you enable tow mode in Forscan like you can enable eco and sport mode?
Maverickman74
Shane
Maui HI
Maybe someone can look up the radiator capacity in their Tremor Owners Manual. That could help with that ID. Anybody think they still put a drive ratio stamp on the diff housings?
Honestly my first assumption with the 2k towing capacity was the springs. They are unique and if they are softer with stiffer shocks(for offroading) then that will decrease the towing right there. Same reason why the Taco TFL did a VS of had a 900lb payload capacity. Extra equipment weight and soft springs. That would mean all we need to make our Mavericks safe for towing 4k, even if they arent legal, is to put some firestone bags in the rear coils.
It is mostly just down to cooling. To get the 30° approach angle, the Tremor cannot use the larger heavy duty radiator from 4k Towing pack. The Tremor will still be highly capable of towing 2k lbs, but Ford's standards for 4k truck towing are extremely stringent.
The Tremor has the same radiator and cooling fan as the Bronco Sport Badlands, which is not shared with the 4k Towing Package. The Tremor/Badlands radiator is shorter in order to accommodate the 30° approach angle.
I think the EPA rating and real-world MPG is due to the tires. I put 5,000 miles on a First Edition Ecoboost non-4K which has the 235/65-17 Falken Wildpeak AT3W that the Tremor has been getting delivered with. (I said it this way because the Tremor marketing photos on shop.ford.com configurator look like Toyo Open Country. But everyone so far has the Wildpeak I believe.)
At any rate, on Wildpeak with 3.73 gears I got 24.1 mpg mostly going 70-84 on the highway. On my current truck, another ecoboost but with the 225/60-18 Michelin Primacy all-season tires and the 3.81 ratio with 4K towing, I was getting 26.2 before winter. (Winter gas blend steals 2-3 mpg every year, any vehicle I drive.)
FischAutoTechGarten
Peter
FischAutoTechGarten
Peter
Try Phoenix with 60+ days a year over 110 and some reaching 120.
That reason alone is justification for the 4K package. Sonoran Desert both in Sonora and Arizona, 75 to 80mph highway speeds, and 110-120degF heats. Want all of the extra cooling that comes with the package.
What I'm not sure of is what exactly does the FX4 package boost in terms of the radiator cooling fan... It looks like it's the same thing in both the 4K and FX4, but just a different way of wording it in the package descriptions.
Ford Maverick Transmission coolers- 4k tow vs. Tremor 1683659188027
Ford Maverick Transmission coolers- 4k tow vs. Tremor 1683659254875
Tremor has a smaller intercooler too, because of the higher ground clearance fascia. Arizona is hell.
Hardening2753
Ford Maverick Hybrid
This was the conclusion I had as well. Same engine, same transmission, same brakes. It's the radiator. Possibly something in the shocks, but that doesn't seem like something that would create an issue.
To me the Tremor could handle 4k fine, if not for short hauls that wouldn't get the radiator and transmission Temps up. I also have some concerns over heat discharge of the Tremor in very hot climates not towing. That would be why FX4 got a radiator upgrade, but Tremor did not. That was honestly one reason I went FX4 vs Tremor, a good bit of my time off road is in very hot Texas summer.
If you look at the engineering magazines about the Ford Maverick they state that the transmissions limitations are mostly due to the cooling. For example the hybrid CVT has a pipe on the side of the radiator, that's it, just a pipe. It does not have a dedicated transmission cooler like the 4K
Hardening2753
Inthe engineering magazines they say that the limiting factor for Maverick is mostly transmission cooling
MavDave
Houston
2022 XLT
DANG! I'm averaging 25mpgs with 265/65/17 on my XLT 4k. That's mixed driving somewhere in the neighborhood of 60/40 surface streets to highway. Hopefully I will be able to get a tank on the highway tonsee what the highway mileage is like.
TC in MN
Minnesota
2022 Ford Mav XLT, CG, 2.0, AWD, Lux, tow, 360
Looks like 4K has a transmission cooler and FX package does not…..
