TPMS for spare tire?
Aherpa
Iowa
Edge, Maverick Lariat Hybrid
I am putting together a set of winter tires/wheels with tire pressure sensors. Does anyone know if these sensors will work will work with the Maverick. The product description lists the Maverick but I thought I'd ask the Club if anyone has had real experience with them.
https://www.tpms.com/Ford-Schrader-33500-EZ-Sensor-TPMS-Sensor-p/ezs0280-f.htm
Also, I'd like to monitor the pressure in the spare tire like some other vehicles do. Does Ford have this feature on any of their vehicles and, if so, can it be adopted for the Maverick (using ForScan for instance)?
Thanks ahead of time.
paneubert
Seattle
Yes 315 is the correct frequency. No, you can't monitor 5 tires on the maverick. The learning process is front left to rear left clockwise direction. It stops the learning process after the 4th tire. So no way to add a 5th.
Don't know about any way to edit this in Forscan. If so, I doubt it would display in the maverick. Would probably be something you had to monitor directly in Forscan when wanting to know the 5th tire pressure. If it was possible at all.
If you want Ford brand sensors, these are them.
Motorcraft TPMS35 Tpms Sensor Kit, 1 Pack https://a.co/d/fdPWtK0
Joseaoe1
Jose
Green Bay, WI
2022 Maverick XLT 2.0 4K VB, 2022 RAV4 Hybrid
Put your spare through the normal tire rotations as well after putting in tpms.
