Tonneaus with rack rails
BlackMav23
MI
2025 Lariat (Shadow Black, 4k Tow, Sunroof)
I meant to mention that you may think about a headache bar or universal roof rack crossbar and hitch extender.
I'm thinking about the Keko Sports Bar and one of those elevated racks that go to your trailer hitch. That setup would be about $800. While that's less versatile I think it would be a little less. The Tri fold wouldn't hit it, and the sports bar looks pretty cool. But I'd mainly be using it for a kayak that would span.
Instead of the Keko bar you could just use a $150 universal roof rack crossbar and do it pretty cheap.
Yeah there's a good amount of options. In my case I would like to leave the hitch unoccupied so I can mount a small motorcycle carrier or cargo rack for cooler, firewood, or any additional cargo should we use up the bed.
I would love to just have a rack on top of the roof, but I'm not a big fan of the type that clamp inside the door frame and I'm leery of adhesives or options that require drilling. I like the idea of leaving the elevate rack on all summer and simply folding down my j racks when not in use even if it is a little more than I want to spend.
Personally I think ford should have given an option for roof rails like the Santa Cruz. I think Ford designers and consumers in general view the Maverick as a smaller version of a traditional pickup. I see it more as a multi-use, one size fits most type of vehicle. Roof rails are an obvious call even if it doesn't fit the truck aesthetic.
gte105u
gte105u
Katy, TX
I will say the Santa Cruz having roof rails and T Slots is nice. Wish they had done this on Maverick.
Heyspike
Hudson Valley NY
www.johnryan.us
C5 - Fairway Green, SIlverado
Interesting thread, I would like the towers to be just under the roof line then add a kayak carrier when I need it. These towers look a bit too tall, is there another option out there?
My Tremor is coming in March I hope.
BlackMav23
MI
If you check out page 2 you'll see someone has shortened the elevate system. May be able to go even shorter.
That's where I'm at. I wanna leave the rack on all summer with a collapsible kayak carrier so I don't have to worry about low cielings in city parking garages and such.
Heyspike
Hudson Valley NY
www.johnryan.us
Looks like the Yakima is adjustable too. Saw one on a ZR2 on You Ttube.
Bear
Oakland County, MI
Ford Taurus & Maverick XLT Hybrid
I have the Elevate racks in the bed and I have them set to the lowest setting. The Elevate racks is slightly above the roof line which should be perfect if/when I decide to install the roof rails. And Yes, I have a messy garage.
Ford Maverick Tonneaus with rack rails IMG_1847
gte105u
gte105u
Katy, TX
Hot Runr Guy
West Chicago, IL
Smack
Minneapolis Minnesota
Ford Maverick 2022
It's winter here in Minnesota so my mileage has taken a hit as is usual with any vehicle. I went from 28.X to 27.X but it's normal, low air moisture reduces the compression so fuel economy goes down. The addition of the rack did make the mileage go down by about 7 tenths.
SkeeterB
The Woodlands, TX
I just noticed your pic! I have the same bed racks and have some questions about your setup. How long is your kayak, do you have any issues driving on the highway (cross wind) with your kayak setup, what kind of kayak mounts do you have and how high does it sit up from the cross bars?
I'm trying to figure out the best & safest way to transport my 17 foot kayak. Part of that process is getting some roof rails installed to give my kayak more tie down since it's so long or do I really need it?
Nice kayak. Mine is 14 feet. The saddles are Malone. To minimize rear overhang it sits very far forward and I use a front tie. At 17 feet you could add a single cheap roof rack with saddles to support the front end. No problems with cross winds so far.
BlackMav23
MI
Does anyone know if the truxedo sentry or something of that nature is compatible with the elevate rack system?
For that matter, if they work in conjunction, how to get one for less than $1000.
I was all set to get a cheap low profile folder but I love the look and (in theory) increased security of the sentry. Rather go that route if I can still use a rack at the same time and find a good deal on it.
ClintonDix
Pennsylvania
23 Maverick
You'll need the TS rails to have the elevate system. On Truxedo's product page for the TS rails they have a cover compatibility guide that says what tonneau cover systems work with and without the TS rails.
BlackMav23
MI
Pretty well updated? I know there's new products coming for maverick all the time. I need to do some research and see if the elevate system is still the best buy.
ClintonDix
Pennsylvania
23 Maverick
I think so , they have the 2023 maverick as an available option for it. if all else fails i'm sure you could call their customer service line and they'd probably be able to give you a concrete answer
gte105u
gte105u
Katy, TX
Truxedo Sentry and Sentry CT are compatible. See link below for confirmed list. Most low profile covers will be. Take a look at the install instructions, it gives you a sense how the TS Rails go in. Then review the install instructions for whatever cover you want. If it looks like it should work probably will.
Basically the TS Rails sit on top of the bed rails, and clam in to the side of the bed rail from below. The covers that sit inside the bed, have a flange over the side, and clamp to side from below should work. I have the TS Rails and the Truxedo Pro X15 sitting at my house waiting for the truck to arrive.
The shortest rails available (50') are what to get, same as the ones that go on the Gladiator. They sell on Amazon for about $180 and includes a set of tie down cleats. I ordered those instead of the factory in bed rail. Figure dual benefit and ability to use even with the bed covered.
As for system about $1k. Do a less expensive cover, the rails, then some cheap cross bars. They won't be high like the elevate rack, but give you extra storage for about 1k.
https://truxedo.com/images/Elevate_Rack_System_Booklet_Jan22.pdf
https://www.amazon.com/Truck-Elevate-1118414-Gladiator-Length/dp/B083GN94DP/ref=mp_s_a_1_3?crid=1D4I258BMJEDZ&keywords=ts+rail+bed+rack&qid=1674251257&sprefix=Ts+rai,aps,193&sr=8-3&ufe=app_do:amzn1.fos.f5122f16-c3e8-4386-bf32-63e904010ad0
https://www.amazon.com/dp/B095L6PB1...olid=1QBH8EFY3P4EE&psc=1&ref_=lv_ov_lig_dp_it
