Tire Pressure & TPMS - What's Your Average Reading?
PeteBerner
Pete
Colorado
24' XL Hybrid
What's your average tire pressure when you check on the dash? Do you feel like it's accurate? I had some trouble getting my TPMS to register on my aftermarket wheels - I got some Schrader ones at Advance Auto parts, and it took Discount Tire a little while to get the truck to recognize them. Like today, when I checked them on the dashboard (hot, driving temperature) 3 of them were at 37 lbs and one was at 36 lbs. That seems within specs, and also hot tire vs. cold tire temperature. I try to keep them at 35 lbs cold, but I'm using the cheap manual tire gauge that they give you at Discount Tire. It seems pretty accurate, but is there a good budget alternative - digital, or with an actual gauge, rather than the one that shoots out like a thermometer? I've always used the cheap freebies, but thought it might be better to get a good tire gauge.
[Edited: I thought I stated this plainly, but I left out asking about accuracy - do you feel like the TPMS is working accurately in your truck? Mine didn't seem too accurate on my old steelies with the OEM TPMS but I think it's better now with the new aftermarket wheels and Schrader TPMS - once I finally got it sorted with Discount Tire. My main reason for the post is that I want an accurate measure of tire inflation (for gas mileage and for tire wear) and I don't want to have to check them every week because the TPMS on the dash is inaccurate, or the Fordpass tire pressure isn't correct.]
dalola
Retired
SE Ohio 🇺🇸
My OEM TPMS has read 5psi low from day 1. And I prefer JACO pressure gauges. 🤠
Hot Runr Guy
West Chicago, IL
PeteBerner
PeteBerner
Pete
Colorado
24' XL Hybrid
Hot Runr Guy
West Chicago, IL
This looks like a good budget option on Amazon -
Screenshot 2025-05-31 at 18-43-51 Amazon.com JACO Deluxe Tire Pressure Gauge - 100 PSI Automot...jpg
thanks for the tip.
Analog (dial) gauges are rated at % of full scale, so a 100psi gauge could be less accurate than a 60psi version. No need to get more gauge than you can use. Too bad they don't offer a 40 or 50psi version.
HRG
GwK
Airdrie Alberta Canada
2025 Maverick
What's your average tire pressure when you check on the dash? I had some trouble getting my TPMS to register on my aftermarket wheels - I got some Schrader ones at Advance Auto parts, and it took Discount Tire a little while to get the truck to recognize them. Like today, when I checked them on the dashboard (hot, driving temperature) 3 of them were at 37 lbs and one was at 36 lbs. That seems within specs, and also hot tire vs. cold tire temperature. I try to keep them at 35 lbs cold, but I'm using the cheap manual tire gauge that they give you at Discount Tire. It seems pretty accurate, but is there a good budget alternative - digital, or with an actual gauge, rather than the one that shoots out like a thermometer? I've always used the cheap freebies, but thought it might be time to change up my tire pressure game!
My TPMS shows 40psi... the body tag indicates 35psi... do I need to take any action?
sanpablo
Rich
Long Island, NY
Carlitos_92
What's your average tire pressure when you check on the dash?... Like today, when I checked them on the dashboard (hot, driving temperature) 3 of them were at 37 lbs and one was at 36 lbs. That seems within specs, and also hot tire vs. cold tire temperature. I try to keep them at 35 lbs cold, but I'm using the cheap manual tire gauge that they give you at Discount Tire.
I can understand wanting tire gauge recommendations, I don't get but the rest of your question.
Are you asking if we think Ford's TPMS readings are accurate? In my experience, my truck is easily within 1 psi of what I see at either my "cheap" gauge, the readout on my air compressor, or the N2 inflators at Costco.
If your intent is a poll of what pressures people are running, then I shoot for 35-37 cold.
Is the 40 psi on hot tires (from driving) or cold?
35 is what you are shooting for when cold. 40 cold is okay but pushing it for comfort and what the tires might reach when hot. I keep mine closer to 35, but your truck is not in imminent danger of exploding or anything.
Buggy Man
Summerfield Fl
2025 Maverick Lobo, Meyers Manx clone dune buggy
I got a decent one from one of the auto part stores, it's made by SLIME - the people that sell that green slime stuff that seal's tire leaking tires. It's digital and seems to be accurate. Cost $13.
Wal-Mart sells them too.
Ozarkbeard
If that's the temperature cold, and if you haven't checked them since you took delivery, it's very likely the dealership never reduced the over inflated tire pressure that's often put in at time of manufacture.
The door pillar sticker probably shows 35 for all four tires on your truck (but could vary). If that's what it says, that's what you should have when you check them on a cool morning before driving the truck.
paneubert
Seattle
Cheap (like less than $5 for a 2 pack) pencil gauges are actually pretty accurate. I have a handful of these.
https://www.amazon.com/dp/B09YYJ58R6?
Accurate to within 2% in the middle of the reading range. I try to use the 10-50 PSI version when checking my tires, but have grabbed the 20-120PSI on accident and it still read the same.
I also have one of these, which claims to be calibrated to the same standard of accuracy.
https://www.amazon.com/dp/B0735HJZ5B?
But the pencil is so much easier and smaller than the floppy dial gauge style.
Robot-Wrangler
Kentucky
SafetyGuy
Andy
Manitoba
I also prefer to run at 1 lb below with the rear tires, as that end is normally lighter. Front at 37 psi, rear at 36 psi...door jam recommended pressure in my 2025 Lariat is 36 psi.
If you experience cold winters, you need to follow and check tire pressures to reflect these colder/lower AM pressures and reverse for summer temperatures.
I measure first thing in the AM, before driving and in the garage to make sure no sun is shining on any of the tires...it really screws up your indicated pressure, if you don't heed this advice.
Manufacturers have factored in the heat created by driving into the recommended COLD temperatures.
This heat will increase your pressure substantially...the hotter the day, the faster you drive, rhe more it will go up.
Cheers
Andy
