GPSMan
Many
  • Thread starter
  • Banned
  • #1
PEAK HYBRID SYSTEM TORQUE: 267 Lb-Ft.
Published Torque:
Gas Engine: 155 lb-ft peak
Electric Motor: 173 lb-ft peak
Unpublished:
Combined hybrid system peak output.
Tested:
Peak Combined Output: 267 lb-ft
(Computer calculated)
Achieved with high (4000 RPM) engine and low (20 MPH) Motor Speed. Peak Torque is with pedal to the floor, truck at 20 MPH.
University of Nebraska did extensive testing of OBDII computer generated torque values vs. dynamometer testing, and found on a 4.5L diesel engine, OBDII computer calculations were consistently higher, but just 2% higher than dyno.
I collected data via OBDII during two full throttle accelerations from zero to 65 MPH. I only had snapshot values at 1 second intervals so the peak may be slightly higher if it occurred between intervals, but the two runs matched pretty closely.
At highway speeds, torque was about 180 Lb - Ft.
The sweet spot: 20-30 MPH.
EB Maverick can sustain the high torque for as long as gasoline supply lasts. Hybrid Maverick will only be able to sustain high torque for 1-2 minutes, or for as long as the battery charge lasts.
But at least, I have demonstrated (to myself anyway) the hybrid is just as good, as the EcoBoost, for getting your heavy load/trailer going from a stop.
Hope you enjoy reading this half as much as I enjoyed testing it.
Of worthy note: there is a stored value in your truck, like the stored value for engine displacement and manufacture date. There is an on board stored value for 100% Torque Reference Point. The value in my Hybrid Maverick: 245.6 which is close to experimental values.
My first run I got a peak of 253.6.
My second run I got 267.
GPSMan
GPSMan
Many
  • Thread starter
  • Banned
  • #2
Peak Torque from Gas Engine in my Test: 149 Lb-Ft.
Peak Torque from the Electric Motor in my Test: 175.5 Lb-Ft.
The peaks do not align at the same point in time. So peak combined was 267 Lb-Ft.
Deleted member 1483
Guest
I am super happy with those results. I knew the actual torque figure would be close to the older 2.0 eco boost (270). I honestly can barely tell the difference from my hybrid and my old escape except maybe highway passing.
I doubt constant peak torque would really be needed in practice. I mean the base model tacoma only has 180lb/ft torque total.
GPSMan
GPSMan
Many
  • Thread starter
  • Banned
  • #4
FYI-
Ford Says Peak Gas Horsepower is at 5600 RPM.
Looks like it is governed to 5600 RPM.
I went to 5604 and it held right there.
Deleted member 1483
Guest
FYI-
That's really neat info. I guess, why do any more?
fossil
ernie
ohio
whats the ice torque at 5600 rpm
GPSMan
GPSMan
Many
  • Thread starter
  • Banned
  • #7
fossil
ernie
ohio
Joeneonturbo
Joey
Turlock, ca
Ford Ranger, Dodge SRT-4
It’s does ‘feel’ quick at certain points
mamboman777
Josh
NRH, TX
Published Torque:
Unpublished:
Tested:
I knew it! Thank you for verifying!
rclee
Rob
Dayton Ohio
Hybrids Rule!;)
I know the EB drivers will hate me for that comment. J/K
Scupking
2025 Ford Maverick XLT Hybrid
Some good numbers for the hybrid system!!
Clarkdonbran
I totally understand all of that!
Ford Maverick Tested: Hybrid Maverick Peak Torque = 267 Lb-Ft 81D1C8D2-A4B9-4D85-AB66-FAB3AEB7E754
fossil
ernie
ohio
That's the beauty of electric motors, 100% of the torque at 1 rpm. As you can see below the hybrid is quicker 45-65 mph which is every day commuting speeds. You can bet Ford set it up for low to mid speed punch. Doesn't really fall off much to the over 50 mph area.
Both charts from https://fastestlaps.com/models/ford-maverick-2-0-t
Acceleration hybrid
45 - 65 mph3.7 s
0 - 30 mph2.9 s
0 - 40 mph4.2 s
0 - 50 mph5.7 s
0 - 60 mph7.6 s
0 - 70 mph9.8 s
0 - 80 mph12.5 s
0 - 90 mph16.0 s
0 - 100 mph20.7 s
1/4 mile15.9 s @ 89.7 mph
Acceleration ecoboost
45 - 65 mph3.8 s
0 - 30 mph2.0 s
0 - 40 mph3.5 s
0 - 50 mph5.2 s
0 - 60 mph5.9 s
0 - 70 mph9.4 s
0 - 80 mph12.4 s
0 - 90 mph15.8 s
0 - 100 mph16.4 s
1/4 mile14.5 s @ 95.0 mph
