My mounting solution. Incredibly sturdy and clean.
You shouldn't have any problems with that one. It's the same one I bought.Update! New APIM purchased.
2021 manufacturing date with Nav this time. I guess I’ll cross my fingers and update you guys sometime this weekend with if it fixed my audio issue and how navigation worked out.
Cross your fingers for me!
Crossing my fingers about the APIM I bought!Splash screen issue fixed! I was able to change a code in the APIM to make the logo bigger!
Now I see the climate commands as small...I search and search but I can't find the code APIM to change the size
Looks like a nice and straightforward solution! Looks like about 1in x 1/8in aluminum flat...did you bend/profile it in a vise?![]()
Yep exactly! bought a little strip of aluminum from lowes for 5$.Looks like a nice and straightforward solution! Looks like about 1in x 1/8in aluminum flat...did you bend/profile it in a vise?
Keep us posted! I have the same audio skip with the stock Sync 3 system and I'm curious if it's APIM related or something else. If the skip happens just as frequently with all 3 of your APIMs I'm led to believe we got a bad batch of ACMs or something like that.Update! New APIM purchased.
I’ll definitely update here once I’ve got the new one installed! Says it’ll be here in a few days.Keep us posted! I have the same audio skip with the stock Sync 3 system and I'm curious if it's APIM related or something else. If the skip happens just as frequently with all 3 of your APIMs I'm led to believe we got a bad batch of ACMs or something like that.
Well I mean I have pretty much everything figured out and working the way I want it. Was really not that bad at all and has been an absolute game changer for this truck. On a road trip right now and loving the new screen.I honestly hope yall get this all figured out and maybe we can have a forscan cheat sheet for this conversion. At the same time. I really wonder if just taking a 25's apim and screen will make this smoother.
What is the unreal Sync Scheme?It works perfectly.
- Unreal Sync Theme (7D0-02-03: xxxx xxx1 xxx-)
- Climate Control at Bottom of Screen (7D0-02-02: xxx6 xxxx xx--)
