yeahiguessman
Angelo
2024 Maverick Lariat
You shouldn't have any problems with that one. It's the same one I bought.
Would you possible be willing to post your as built data from Forscan for the APIM? I cannot for the life of me get everything to work properly. Though I think I have another borked system.
801Maverick801
Utah
Subaru Forester
Just an update for everyone. Everything seemed perfect but suddenly CarPlay started acting up. Bluetooth audio works perfect now, but when wired into CarPlay and tapping the screen to switch apps (say to maps) or when an app like maps does a background refresh audio stutters and skips pretty drastically.
I tried resetting the system and my phone as well as trying both USB ports with two different cables and the same thing happened.
I must either be deeply unlucky or my truck just does not want to play nice with this swap.
Not sure what to do at this point other than revert to Sync 3 and move on.
Did you change the ACM to the Bronco sport or modify the ACM hex code at all?
yeahiguessman
Angelo
I hadn't touched that. Is there something I should do in the ACM that might help? Also, would you be willing to share your as built data for your APIM at all? I cannot figure out how to renable wireless app projection. Accidentally disabled it when programming earlier.
Billzilla15
Billzilla15
Ohio
22 Maverick Lariat
Disconnect the battery. Do a hard reset
yeahiguessman
Angelo
It’s just odd because it seems like a software issue. CarPlay is the only thing that causes audio glitches when using USB audio. I can be plugged into USB audio and tinkering in Sync settings and music will be fine.
For instance, when using CarPlay with my phone or Android Auto with a friends phone and displaying a music app, music plays fine. It’s when switching tasks like going to maps, scrolling through the music apps library, or through recent call history that causes the music to skip or stutter. Almost like the processing power can’t keep up with the basic tasks.
Which is odd because from my understanding AA and CarPlay are controlled by the phone and the infotainment screen basically just mirrors what your phone is doing, so there shouldn’t be any issues there?
I’ll try a hard reset as rebooting and resetting the head unit don’t work, but I’m leaning more on me just getting unlucky.
801Maverick801
Utah
Subaru Forester
Were you a lariat to begin with?
I will get you my asbuilt in a little bit.
Just keep in mind, my Asbuilt is catered to a very basic system. I really only modified Forscan to have Android Auto, back-up camera, ambient lighting. I am not using Nav/Sat Radio/HD radio ect.
yeahiguessman
Angelo
I have a Lariat, yes. I would seriously appreciate that so much if you could get me your Asbuilt! You’d be a life saver.
So eager to finally wrap this project up
yeahiguessman
Angelo
Seriously appreciate this. Yours looks a lot different in some areas than mine, so I’m just going to line by line check those areas and see what works or doesn’t.
Did you use the 13” Escape screen or the 12” Transit screen?
801Maverick801
Utah
Subaru Forester
No worries!
It's the 12 inch transit screen.
I tried to use the original posters as built but he had the 13 inch screen so I was having too many issues with the display.
The APIM is from an f150 so a ton of that code is for an f150. Should be a good starting point for you though, and at least the main things will be functional from the beginning.
yeahiguessman
Angelo
No worries!
I’m using a 2021 F150 APIM so this should definitely be a good starting point. Hoping my buggy audio and Wireless CarPlay turning off is a result of a programming issue since it seemed perfect prior. I’ll check back in later tonight with hopefully good news!
Thanks so much again!
pantera156
Pantera
Porto Alegre
lariat 2.0
Do you want me to send you my configuration?
Please change the theme, it helps a lot.
801Maverick801
Utah
Subaru Forester
After seeing some install pictures from a low level, I was initially worried about the 12 inch transit screen being too tall and impeding view.
I'm 5'8" and these were taken at eye level. It is the perfect height, no issue with view.
Ford Maverick Sync4 APIM and 13.2" Screen Installation Guide (Lariat Models) 20250108_173234
Ford Maverick Sync4 APIM and 13.2" Screen Installation Guide (Lariat Models) 20250108_173207
