801Maverick801
Utah
Subaru Forester
Ford Maverick Sync4 APIM and 13.2" Screen Installation Guide (Lariat Models) 20241227_211000
I still can't believe how nice this setup is.
Also, I got the rear view camera to work in Easy mode in Forscan.
I disabled ''digital rear camera" and then it worked. I'm guessing the Maverick camera doesn't send a digital signal?
yeahiguessman
Angelo
2024 Maverick Lariat
801Mavs mounting solution is significantly better and more clever than mine, so if anyone is wondering just go with his!
Here’s some photos from the front and back of how it turned out now that everything is secured
Will be purchasing a different APIM next month to fix the slight audio issue. It’s not bad enough to really bother me for now.
Everything else works! 98% there
Ford Maverick Sync4 APIM and 13.2" Screen Installation Guide (Lariat Models) IMG_0563
Ford Maverick Sync4 APIM and 13.2" Screen Installation Guide (Lariat Models) IMG_0559
yeahiguessman
Angelo
Update! New APIM purchased.
2021 manufacturing date with Nav this time. I guess I’ll cross my fingers and update you guys sometime this weekend with if it fixed my audio issue and how navigation worked out.
Cross your fingers for me!
Ford Maverick Sync4 APIM and 13.2" Screen Installation Guide (Lariat Models) IMG_0581
pantera156
Pantera
Porto Alegre
lariat 2.0
You shouldn't have any problems with that one. It's the same one I bought.
pantera156
Pantera
Porto Alegre
lariat 2.0
Splash screen issue fixed! I was able to change a code in the APIM to make the logo bigger!
Now I see the climate commands as small...I search and search but I can't find the code APIM to change the size :crying:
Ford Maverick Sync4 APIM and 13.2" Screen Installation Guide (Lariat Models) photo_2024-12-30_00-27-06
yeahiguessman
Angelo
Crossing my fingers about the APIM I bought!
I will say I had this same issue with my software and ended up removing the section in Forscan completely because I couldn’t resize it properly.
801Maverick801
Utah
Subaru Forester
Looks like a nice and straightforward solution! Looks like about 1in x 1/8in aluminum flat...did you bend/profile it in a vise?
Yep exactly! bought a little strip of aluminum from lowes for 5$.
I installed rivnuts into the aluminum for those Torx bolts, makes it way easier. Held the screen in and just eye-balled the bends and threw it in the vice with some heat and made the bends, really took no time and is very solid.
CaptBanana
Massachusetts
'23 Lariat Lux Hybrid, '06 Chevy Cobalt
Keep us posted! I have the same audio skip with the stock Sync 3 system and I'm curious if it's APIM related or something else. If the skip happens just as frequently with all 3 of your APIMs I'm led to believe we got a bad batch of ACMs or something like that.
yeahiguessman
Angelo
I’ll definitely update here once I’ve got the new one installed! Says it’ll be here in a few days.
With my Sync3 I had an initial audio skip when playing USB or Bluetooth audio probably like thirty seconds in to each song? But it would typically only do it once a track.
With this there’s a slight pop or crackle a few times a song, but only when playing USB or Bluetooth audio. AM/FM radio and SiriusXM play perfectly.
When swapping in my old Sync3 the original issue was there, but not the Sync4 issue I was facing now. I think it’s software based which is a pain because it’s a real hassle to update the software once you do this swap. It’s cheaper for me to just get a different APIM that’s going to have an earlier software version installed.
Anyways, I’ll update once it’s all hooked up! Cross your fingers for me!
pantera156
Pantera
Porto Alegre
lariat 2.0
  • Unreal Sync Theme (7D0-02-03: xxxx xxx1 xxx-)
  • Climate Control at Bottom of Screen (7D0-02-02: xxx6 xxxx xx--)
It works perfectly.
Dmat
Baton Rouge
MAVERICK
I honestly hope yall get this all figured out and maybe we can have a forscan cheat sheet for this conversion. At the same time. I really wonder if just taking a 25's apim and screen will make this smoother.
801Maverick801
Utah
Subaru Forester
Well I mean I have pretty much everything figured out and working the way I want it. Was really not that bad at all and has been an absolute game changer for this truck. On a road trip right now and loving the new screen.
