pantera156
Pantera
Porto Alegre
lariat 2.0
I just did the 12" with an f150 apim module. Only issue running into is blue screen on my backup camera..going to dive into Tonight or tomorrow.
We are waiting for the photos of the project.
I am waiting for everything to arrive so I can start with mine. (With a 12" screen) :clap:
Billzilla15
Billzilla15
Ohio
22 Maverick Lariat
I had this when I first started. I turned off every single thing related to the camera and went one by one till it worked. Took forever but it works now
Linux
Washington (Seattle Area)
2012 Mustang, 2024 Maverick Lariat
I just took it all apart, the pin for number 14 in the apim was short? looks like it was made improperly, fixed that and its all working. @Billzilla15 how did you update with forscan? Did you have to use asbuilt to update right now it keeps disabling me from updating.
Billzilla15
Billzilla15
Ohio
22 Maverick Lariat
I used whatever it is where you put the numbers in . Not the easy multiple choice version
Billzilla15
Billzilla15
Ohio
22 Maverick Lariat
@Billzilla15 what did you do to make fordpass work? Mine just thinks it's in lowe power mode and it clearly is not
Did you disconnect the battery. I basically hot swapped mine and had no issues with mine working.
From what I've gathered is sync 3 needs to be in and working . And just hot swap for the sync 4
Linux
I did not hotswap, it was directly to disconnect the battery. I will see about popping it back in start it up and swap it that way :sad:
Linux
Might just shove back in my sync 3 at this point. Seems like apim module is not communicating with the accm or bdycm or HVAC modules. If anyone has any suggestions let me know. Might be a cable issue
Billzilla15
Billzilla15
Ohio
22 Maverick Lariat
You got everything plugged in? My as built data I think is on one page in here if you want to give that a shot
Linux
Yep took every out three times verified plugged in and same issue nothing communicating with the apim, went ahead and just reverted back to sync3. I think the apim is bad
The clarify most things worked, backup camera Android auto, audio etc, but overlays would not work for backup, audio, HVAC, controls like acc would not communicate. Why this is an issue can't see audio volume or temperature. I really really like screen and everything, might try to make my own harness adapter as this might be the problem and the cheapest way to move forward
Linux
Just a quick update, the passthrough cable I have is junk, pins not properly sticking out picked up one like OP did and going to make my own. This process has been frustrating not with the work needed but getting bad wiring :(
ryan2366
Ryan
2025 Maverick Lariat - Hybrid AWD
thanks for sharing this! Just swapped in a 12” on my Lariat hybrid using this as a starting point. Using a couple plastic spacers, longer bolts, and a 100mm straight bracket for the passenger side bolt I was able to just bend the middle mount point on the screen down, cut out the plastic back cover of the screen, and bolt right in securely. Little large of a gap on the right side of my screen but otherwise looks great.
My boot screen aspect ratio is weird though, and not sure what controls that if anyone has an idea where that’s set in forscan?
Also careful for anyone doing this, don’t reset the sync 4 APIM settings or you’ll lose the app. Think I’d have to reinstall the sync 3 one to get it back sadly.
Did you take any pictures of how you mounted it?
Toddman45
St. Louis, MO
Looks good, but wouldn't the aspect ratio of the 13.2 screen have the screen height lower?
Toddman45
St. Louis, MO
I had picked up a 13.2 off LKQ originally, but I couldn’t see how you’d mount that without it sticking out or fitting weird. Props to the others who made it look good, I’m content with a slightly smaller screen.
It might be smaller width wise, but heightwise it's bigger. Especially compared to the 13.2 in screen that comes in my dad's 23 Corsair or the new 25 Mavericks.
Personally I'm hoping once the 25s hit owner's hands people start modifying the 22 through 24's making it easier upgrade to sync 3, as if it's around 500 to upgrade to a sync 3 APIM I'll be all over it. Because the sync light in my 24XLT is horrible.
