pantera156
Pantera
Porto Alegre
lariat 2.0
I just did the 12" with an f150 apim module. Only issue running into is blue screen on my backup camera..going to dive into Tonight or tomorrow.
We are waiting for the photos of the project.
I am waiting for everything to arrive so I can start with mine. (With a 12" screen) :clap:
Billzilla15
Billzilla15
Ohio
22 Maverick Lariat
I had this when I first started. I turned off every single thing related to the camera and went one by one till it worked. Took forever but it works now
Linux
Washington (Seattle Area)
2012 Mustang, 2024 Maverick Lariat
I just took it all apart, the pin for number 14 in the apim was short? looks like it was made improperly, fixed that and its all working. @Billzilla15 how did you update with forscan? Did you have to use asbuilt to update right now it keeps disabling me from updating.
Billzilla15
Billzilla15
Ohio
22 Maverick Lariat
I used whatever it is where you put the numbers in . Not the easy multiple choice version
Billzilla15
Billzilla15
Ohio
22 Maverick Lariat
@Billzilla15 what did you do to make fordpass work? Mine just thinks it's in lowe power mode and it clearly is not
Did you disconnect the battery. I basically hot swapped mine and had no issues with mine working.
From what I've gathered is sync 3 needs to be in and working . And just hot swap for the sync 4
Linux
I did not hotswap, it was directly to disconnect the battery. I will see about popping it back in start it up and swap it that way :sad:
Linux
Might just shove back in my sync 3 at this point. Seems like apim module is not communicating with the accm or bdycm or HVAC modules. If anyone has any suggestions let me know. Might be a cable issue
Billzilla15
Billzilla15
Ohio
22 Maverick Lariat
You got everything plugged in? My as built data I think is on one page in here if you want to give that a shot
Linux
Yep took every out three times verified plugged in and same issue nothing communicating with the apim, went ahead and just reverted back to sync3. I think the apim is bad
The clarify most things worked, backup camera Android auto, audio etc, but overlays would not work for backup, audio, HVAC, controls like acc would not communicate. Why this is an issue can't see audio volume or temperature. I really really like screen and everything, might try to make my own harness adapter as this might be the problem and the cheapest way to move forward
Linux
Just a quick update, the passthrough cable I have is junk, pins not properly sticking out picked up one like OP did and going to make my own. This process has been frustrating not with the work needed but getting bad wiring :(
wafflenator
Denver, CO, USA
2022 AB Lariat Hybrid
this is my current working as built. enjoy
Module=7D0 (APIM - Accessory Protocol Interface Module (SYNC))
01-01 A085 0A00 8088
01-02 0000 D609 00B9
01-03 C390 0020 0C5A
01-04 02E0 8080 00BE
02-01 0722 000F 283A
02-02 C000 00D0 60CB
02-03 A040 1001 00CD
03-01 5553 0B04 099B
03-02 0300 0605 00EA
03-03 0901 0000 00E7
04-01 4578 0078 0011
05-01 0004 2800 0009
05-02 0102 00CF DA8A
05-03 4BE7 0000 0011
06-01 1874 18C4 296F
06-02 AE8D
07-01 1500 3300 0027
07-02 0000 5EA1 00DF
07-03 0056 5681 000E
07-04 886A
08-01 CE00 0001 00AF
08-02 0000 0000 00E1
09-01 03A8 AC70 18C0
09-02 0033 0000 182D
09-03 0033 0000 0016
09-04 0240 0000 E006
09-05 2014 0000 2039
10-01 0000 0000 00E8
10-02 0000 0000 00E9
10-03 0000 0000 08F2
10-04 0000 0000 00EB
10-05 0013 E000 00DF
thanks for sharing this! Just swapped in a 12” on my Lariat hybrid using this as a starting point. Using a couple plastic spacers, longer bolts, and a 100mm straight bracket for the passenger side bolt I was able to just bend the middle mount point on the screen down, cut out the plastic back cover of the screen, and bolt right in securely. Little large of a gap on the right side of my screen but otherwise looks great.
My boot screen aspect ratio is weird though, and not sure what controls that if anyone has an idea where that’s set in forscan?
Also careful for anyone doing this, don’t reset the sync 4 APIM settings or you’ll lose the app. Think I’d have to reinstall the sync 3 one to get it back sadly.
Ford Maverick Sync4 APIM and 13.2" Screen Installation Guide (Lariat Models) IMG_0098
ryan2366
Ryan
2025 Maverick Lariat - Hybrid AWD
Did you take any pictures of how you mounted it?
Toddman45
St. Louis, MO
Looks good, but wouldn't the aspect ratio of the 13.2 screen have the screen height lower?
