Momo
Quebec
Yep. That's built into sync 4. It's almost instant on boot. Way better than the AAwireless dongle I was using. Also it's way more stable. The stock radio was freezing on me all the time and I would have to force rest it.
Toddman45
St. Louis, MO
Looks great guys, service department will be scratching they're heads next time you visit for a oil change or maintenance...😁👍
  • Haha
Reactions: bgn
Dmat
Baton Rouge
MAVERICK
@Momo did you have to use an apim from the save vehicle as the screen?
Billzilla15
Billzilla15
Ohio
22 Maverick Lariat
just use same year or newer apim and youll be good.
we ran into issues with the escape 13.2 screen because the programing wasnt in a 22 apim and the screen is 23
dfitz
2024 Maverick Lariat 2.0L EB
So I'm all done. Thanks to everyone in this thread. I started out with a XLT so I had to combine this tutorial with the one about adding sync to the XLT. I also went with a 12" Transit screen instead of the 13.2" escape screen. I prefer the taller more square aspect ratio. The only thing is it's just a tad smaller than the original radio cutout so it leaves a small gap. I plan on filling the gap with sugru unless someone has a better idea. Thanks again to everyone.
Were you able to use the existing mounting provisions from the original screen?
dfitz
God no. I took the one from the 8" screen, did a bunch of modifying and then slapped it on. It's not pretty but you can't see it.
I figured that would be the case. I have the larger screen to mount once my cables come. The 12” fits the opening better for retrofitting.
With the larger screen, maybe later the MY25 dash piece will be available. I would relocate the radio controls even though I never use them just to have the hazard indicator for safety. Maybe put them in/near the glovebox if the cable can reach.
So what would a Lariat that already has Sync 3 need to install just the 12" Transit screen?
Screen (obviously)
WPT-982
Mostly unclear on what would be needed on the APIM side:
Camera adapter cable (or would there already be one of these to splice into?)
12" APIM?
NC3T14F664AA screen to APIM? Or is there already a compatible LVDS cable?
dfitz
Screen (obviously)
WPT-982
12" APIM?
You'll need the items in the original post but instead the 12" screen so sync4 APIM, passthrough, power cable and the screen cable.
dfitz
I finished modifying my passthrough harness today. I took my time but it turned out great. Now to find some time to pull the truck apart to install everything and see if it works.
Ford Maverick Sync4 APIM and 13.2" Screen Installation Guide (Lariat Models) IMG_3183
Ford Maverick Sync4 APIM and 13.2" Screen Installation Guide (Lariat Models) IMG_3186
Redneck Garage
Franklin TN
www.theredneckgarage.com
You can also purchase a 12 to 13.2" upgrade kit from fordsync4.com
Looks pretty nice but a bit pricey.
I have purchase one of their kits - FYI they are scumbags. Take days to answer emails, product specifications are questionable- not even sure if they give instructions on the Forscan modifications.
Linux
Washington (Seattle Area)
2012 Mustang, 2024 Maverick Lariat
I just did the 12" with an f150 apim module. Only issue running into is blue screen on my backup camera..going to dive into Tonight or tomorrow.
