Anybody running into audio settings like EQ resetting after restarting the vehicle?
probably a sign of a weak 12v battery, but another explanation is after the dealer does software updates.
pantera156
Pantera
Porto Alegre
lariat 2.0
Has anyone been able to get it to display the full TRIP data? It only shows the remaining range, but not the other data. :crying:
Ford Maverick Sync4 APIM and 13.2" Screen Installation Guide (Lariat Models) photo_2025-09-15_00-35-21
Bobert47
Bobert
Kentucky, US
2023 Ford Maverick Lariat
I haven't been able to get the trip data to show on the infotainment screen at all on my setup (I didn't dig into it too far to be honest since it shows up on the instrument cluster screen for me still). I'm using CarPlay with the SYNC side panels if that is of any concern.
airmanadams88
Ohio
2024 Maverick Lariet
Just listed my full 12” sync4 setup for lariat sync 3 in marketplace if anyone’s looking for one of these setups.
Billzilla15
Billzilla15
Ohio
22 Maverick Lariat
You need a matching dash to do it. Once I swapped to the escape cluster it started working. The stock one won't talk to the sync 4
MattinNC
Raleigh, NC
'23 Lariat
@Bobert47
I'm in the process of completing my install of the 12" screen with a "24 Escape APIM and the ACM from a '23 Maverick. Your install post was a big help! In the haste to get it working I forgot to backup up the As-Built from the ACM. Would you consider sharing your As-Built from your ACM? I have a Lariet but didn't have the
Sync 3.
Bobert47
Bobert
Kentucky, US
@Bobert47
Sync 3.
Hey MattinNC, here you go, Merry Christmas! :)
The images overlap, its not as many lines as it seems. Sorry its not in a table to copy from, I'm on my phone and already on my holiday travels. Hope it helps and thanks for the shout out!
Ford Maverick Sync4 APIM and 13.2" Screen Installation Guide (Lariat Models) 2023 Mav Lariat Hybrid ACM -1
Ford Maverick Sync4 APIM and 13.2" Screen Installation Guide (Lariat Models) 2023 Mav Lariat Hybrid ACM -2
Ford Maverick Sync4 APIM and 13.2" Screen Installation Guide (Lariat Models) 2023 Mav Lariat Hybrid ACM -3
FYI on phone.
Open file copy the part that is longer than one screen then save that as a new file with an assigned file name. Then while replying to mtc post attach the saved file. (Possibly as full size if it's not longer than 3-4 screen lengths). Then viewer can scroll through that file even on his phone. Or he can Wi-Fi print the portion he wants.
Bobert47
Bobert
Kentucky, US
FYI on phone.
Thanks for the tip! Those were existing screenshots I had saved, just posting with my phone since I'm not with my Mav at the moment. On an tangentially related note, anyone hear more on the rumors the version of FORscan currently in dev being able to do module firmware updates outside FDRS (like for our APIMs)? Long shot but that would be cool.
I have android don't know about apple but suspect it's capable, also.
From menu click share then choose either copy file link OR "LONG SCREEN" then size with arrows by scrolling and selecting what portion of scrollable area you want to save. Can choose many screen lengths then click ok checkmark then save. File will be in downloads and recent files to attach.
MattinNC
Raleigh, NC
'23 Lariat
Bobert, Thank you so much for posting! I appreciate it. I wanted to have another Hybrid to compare the ACM. I have the "23 Hybrid Lariat but without the B&O system but it should be pretty close.
MattinNC
Raleigh, NC
'23 Lariat
Anyone do this swap in a Lariet hybrid without the B&O system and got the Ford Pass app working? I've got everything else working like I expect but I can't seem to find the correct settings in Forscan to get the app to connect.
MattinNC
Raleigh, NC
'23 Lariat
Success! I believe I have everything working now as it should. I did have to reconnect the ACM to get the Ford Pass to connect. I'm going to share a few things I did differently for my install but of course the information on this and other threads have done all the heavy lifting.
An interesting screen @Bobert47 posted, I'd like to know how you access this screen? It looks like it in Apps. Maybe connected services, which I don't appear to have.
Ford Maverick Sync4 APIM and 13.2" Screen Installation Guide (Lariat Models) mav-hybrid screen
breeves002
Sam
St. Louis, MO
Someone sent me this today and I decided to do a deep dive here and figure it out.
Make sure hybrid is enabled:
7D0-02-02 xx8x xxxx xxxx
Enable the power flow menu:
7D0-02-02 xxx6 xxxx xxxx WITH climate bar enabled
7D0-02-02 xxx4 xxxx xxxx WITHOUT climate bar enabled (what you have pictured).
I don't have access to a hybrid so I can't actually confirm this works but I'm pretty sure it will. Report back with your findings!
If you just want to enable the climate bar layout:
Enable unreal theme:
7D0-02-03 xxxx xxx1 xxxx
Enable Climate bar for non-hybrid:
7D0-02-02 xxx2 xxxx xxxx
If things look weird or don't show up reboot the apim by holding power and next track for 10s or reprogram nothing into it, or reboot with FORScan.
As always any parts or programming you need for these upgrades check out www.oemplusupgrades.com!
Bobert47
Bobert
Kentucky, US
Thanks for addressing this! I took that picture just after getting my build setup. I can confirm that those lines are what I needed to get the screen working. I will add that the "trip" screens that will show up on the this mod (if enabled) don't synchronize with the the "trip" on the cluster. I learned this from another user on here, and that you would need to swap out your cluster for a 2023 escape (or similar from what I recall). Anyway not specifically pertinent to this part, but the power flow screen does work very well. Happy New Year All!
