Bobert47
Bobert
Kentucky, US
2023 Ford Maverick Lariat
Finally got around to attempting to program my install yesterday. 21' F150 apim and 23 lariat Maverick ACM into my 23 XLT. So I copied over Bobert47's built from back on page 19. I was fighting getting my GPS to work correctly. This resolved that issue with it jumping around madly. So now I am only down to two problems. Both my usb ports no longer function (saw they are controlled from the ACM(will have to investigate that)) and secondly my volume knob works, but the screen pop up never changes from 0. All the other buttons work and display the information as they are supposed to. Seeing if someone had some directional guidance. Thank you
Happy to have been a help! The volume knob working but showing zero I also ran into at first, it was a cluster group selection when I was adjusting radio and hvac configs, so I'd look there first. For the USB ports, I'd double check you don't have a loose pin or wire in your harness to the APIM (I ran into that once as well). Sounds like you're most of the way there 👍
Killerrudy
B rian
Ohio
2023 Maverick
Thanks for the quick reply. I didn't think to check the wiring for the USB not working as it was one of those pre built harnesses that I got thru here. Well after I missed that there was a group discount of course.. 😞
yeahiguessman
Angelo
2024 Maverick Lariat
Anybody running into audio settings like EQ resetting after restarting the vehicle?
Cactus22
B
2022 Maverick, Cactus Grey
Mine sticks. I got it pre programmed from OEM, and everything is working (other than nav - known issue). It all works as expected
probably a sign of a weak 12v battery, but another explanation is after the dealer does software updates.
pantera156
Pantera
Porto Alegre
lariat 2.0
Has anyone been able to get it to display the full TRIP data? It only shows the remaining range, but not the other data. :crying:
Ford Maverick Sync4 APIM and 13.2" Screen Installation Guide (Lariat Models) photo_2025-09-15_00-35-21
Bobert47
Bobert
Kentucky, US
I haven't been able to get the trip data to show on the infotainment screen at all on my setup (I didn't dig into it too far to be honest since it shows up on the instrument cluster screen for me still). I'm using CarPlay with the SYNC side panels if that is of any concern.
airmanadams88
Ohio
2024 Maverick Lariet
Just listed my full 12” sync4 setup for lariat sync 3 in marketplace if anyone’s looking for one of these setups.
Billzilla15
Billzilla15
Ohio
22 Maverick Lariat
You need a matching dash to do it. Once I swapped to the escape cluster it started working. The stock one won't talk to the sync 4
MattinNC
Raleigh, NC
'23 Lariat
@Bobert47
I'm in the process of completing my install of the 12" screen with a "24 Escape APIM and the ACM from a '23 Maverick. Your install post was a big help! In the haste to get it working I forgot to backup up the As-Built from the ACM. Would you consider sharing your As-Built from your ACM? I have a Lariet but didn't have the
Sync 3.
Bobert47
Bobert
Kentucky, US
@Bobert47
Sync 3.
Hey MattinNC, here you go, Merry Christmas! :)
The images overlap, its not as many lines as it seems. Sorry its not in a table to copy from, I'm on my phone and already on my holiday travels. Hope it helps and thanks for the shout out!
Ford Maverick Sync4 APIM and 13.2" Screen Installation Guide (Lariat Models) 2023 Mav Lariat Hybrid ACM -1
Ford Maverick Sync4 APIM and 13.2" Screen Installation Guide (Lariat Models) 2023 Mav Lariat Hybrid ACM -2
Ford Maverick Sync4 APIM and 13.2" Screen Installation Guide (Lariat Models) 2023 Mav Lariat Hybrid ACM -3
FYI on phone.
Open file copy the part that is longer than one screen then save that as a new file with an assigned file name. Then while replying to mtc post attach the saved file. (Possibly as full size if it's not longer than 3-4 screen lengths). Then viewer can scroll through that file even on his phone. Or he can Wi-Fi print the portion he wants.
Bobert47
Bobert
Kentucky, US
FYI on phone.
Thanks for the tip! Those were existing screenshots I had saved, just posting with my phone since I'm not with my Mav at the moment. On an tangentially related note, anyone hear more on the rumors the version of FORscan currently in dev being able to do module firmware updates outside FDRS (like for our APIMs)? Long shot but that would be cool.
I have android don't know about apple but suspect it's capable, also.
From menu click share then choose either copy file link OR "LONG SCREEN" then size with arrows by scrolling and selecting what portion of scrollable area you want to save. Can choose many screen lengths then click ok checkmark then save. File will be in downloads and recent files to attach.
MattinNC
Raleigh, NC
'23 Lariat
Bobert, Thank you so much for posting! I appreciate it. I wanted to have another Hybrid to compare the ACM. I have the "23 Hybrid Lariat but without the B&O system but it should be pretty close.
